Question about Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit
I only get channel 184 - help!
I was very happily listening, then my radio cut out, and on came the weather/emergency channel. I can't seem to get it to pick up other channels.
What is the problem?
  • dougjharvey Apr 07, 2008
    I cannot get channels 1 thru 45 on my car radio, everything we fine, then boom. I spoke to the provider and they updated giving me channel 198 so I a know I am connected. Did I hit some kind of button on my radio. I drive a 2007 Jeep Patriot Limited
This hapened to my s50 the day after my semi annual payment went through (thought it was a CC problem) No, it just died? First the logo screen was on freeze mode..looked up on outher forum..same issues. the "3 Finger salute" worked for some, but not all..its a risky procedure.
Anyway, I received a MUST UPGRADE FIRMWARE for the S50...new verison of Sirius Sudio...no go. I was on the phone with Leah CS Rep..helpful, she tried. Apparently this this is dead.
Went through the 3 Finger procedure..looked like it was going to work, stuck on FIRMWARE UPDATING...then the receiver shuts down. Shes sending me a new unit..sucks it is a major downgrade, the real basic Stratus 4 with thatamber screen, ugh.
Only thing good about this, I can use it as an MP3 player
Posted on Apr 15, 2008
    Problem Solver:
  • 6 Answers
Call Sirius and verify your account is still active. Also, on the S50 make sure you can see your ESN number. If you can, go to the menu and Reset Channels. If you can't do that on your car kit, try it on your home kit.
Posted on Feb 19, 2008
SOURCE:
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Don't talk to each other
What channel do you have to listen to the weather
Mar 10, 2013 | Motorola T8500 Two Way Radio
Hi i have a radio shack hanheld trc-231 and a trc-241. I would like to know how i can tweak my trc231 to the max and i need to find out whats wrong with my trc241 as it has a weak transmitting signal out...
First , make an external antenna and listen.
You can make one ,
• with a use of a 9 ft long , 1 in diam aluminum tube,
• RG-58 cable and
• BNC antenna connector for your radio
Install it above the roof , 10 ft height of mask is OK
higher is better
• Use 4 guy wires as ground.
Jul 29, 2012 | Radio Communications
Can i catch outdoor frequencies like polce etc?
It is possible if you have a radio programmed to police or emergency frequencies, or better yet, a scanner. Your local electonrics store should be able to help you with this.
Best regards.
Jul 01, 2012 | Motorola Talkabout T6500 (7 Channels)...
How do I program a Midland GXT760VP4
After installing and charging the battery pack (or installing alkaline batteries), turn on the radio by turning . Then press Menu once to set your Channel. Press Menu additional times to set other features. To set the channel to listen to Weather Radio, continue pressing Menu to the Weather Channel sub-menu (Channel 1 is 162.400 MHz). If you press and hold Menu for more than 5 seconds with the radio in GMRS mode, the radio will scan all 10 weather radio channels.
Midland has the manuals to many of their products here: http://www.midlandradio.com/Two-Way-Owner-Manual . The direct link to the manual is http://www.midlandradio.com/Resource_/OwnerManual/201/GXT760%20Owner%27s%20Manual%20.pdf .
Please let me know if there is a specific item you want to set up on the GXT760VP4.
Nov 18, 2011 | Midland Radio Communications
How do i program my eton fr 800 radio to come on automatically. Thank you.
  • To get your alert radio to come on when there is a weather alert first you needed to find the right NOAH frequency to turn on automatically to.
  1. Extend the antenna fully.
  2. Turn on the radio.
  3. .Press the "WB" button at the top of the radio.
  4. Turn up the volume and press the ^ or v button to cycle through all 7 of the weather channels.
  5. WB and CH will appear at the top of the display., with 1-7 next to CH.
  6. Select the strongest channel you can hear (if you can hear more than one channel. Usually only one channel is heard).
  7. The strongest one is the broadcast from your area.
  8. Now adjust the volume you want the radio to turn on in the event of an emergency.
  • Now once you have the weather frequency set for the radio to turn on to, we need to make it able come turn on in an emergency.
  1. Press the ALERT/WB button at the top of the radio.
  2. The alert light shines in the upper left corner of the radio.
  3. The audio will disappear but the radio is still on.
  4. It will monitor Noah until an emergency occurs and at that point a siren or a voice will alert you. Then you press the WB button to hear the alert.
Regards, Tony
Apr 27, 2011 | Audio Players & Recorders
Please provide the way to program weather alert for Lewis Co TN
Click this website-http://www.nws.noaa.gov/nwr/CntyCov/nwrTN.htm. Your county has 4 frequency channels, so you will have to try the channels on your radio and the one that receives the best reception, is the one that you should listen to.
Jun 16, 2010 | Midland WR-100 Weather/RDS Radio
Satellite radio (REF) not connecting with Sirius.
Do you have a paid subscription? IF you do, call and have them with your radio's serial number and ask them to 'refresh' your radio to restore the other channels. If you only have channel 184 and CH1, it sounds like you haven't purchased a monthly subscription yet.
Dec 21, 2009 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
While receiving the receiver cuts out momentarily approximately every 10 seconds
This sounds like you have the "Weather Alert" function turned on. With this on, the radio will check for an emergency signal on the weather channels about every 10 seconds.
Oct 07, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Logo
567 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Perry Mellott
Perry Mellott
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
