Question about LG 30FZ4D TV
How do you get into the service menu for a LG WE-32Q10IP TV?
Had an engineer fix(?) my TV a while back and he adjusted the width and pincushion using a service menu. He left the set in a real mess and to be honest I don't think he really knew what he was doing.
So how can I access this menu to put the set right please.
Thanks
Mike
Press and hold menu button on your TV and menu button on your remote at the same time.
Posted on Apr 19, 2009
SOURCE:
Screen too wide on lg tv
you hav''nt specified tv model but you need to have a service code of that model press this service code after pressing menu
Jan 08, 2013 | LG 3911TKK748A DU-42LZ30 Main Board
How do i increase the screen resolutions for the lg we-32Q10IP
I am fairly sure in VGA it is a fixed resolution---give LG a call with the model number and see how smart their customer service people are.
May 24, 2012 | LG Televison & Video
How to set the width of LG ultraslim 218AZAG3T8 TV USING SERVICE MENU AND HOW TO OPEN IT
hlo sir plz help me i am some problem in Lg television .
this tv was see graphic but doesnt wathch people .
then how to solve in this tv.
plz sir help.i am waiting in your answer...............
Mar 29, 2012 | Televison & Video
Picture image does not look full when showing people
There is a service menu adjustment. I have seen several of these sets with bad components in the horizontal width control circuit. maybe your other set has a width problem. put both on the same channel. like cnn with the ticker on the bottom. what is the difference in size?
the width adj. procedure is: with the set off. use the remote, enter. MENU>5>VOL+>POWER . the set will come on in the service mode. then with the menu adj. buttons you can step threw the service menu to H.WIDTH adj. until full picture. also VERT. HEIGHT. when you are done adjusting make sure you press the mute button and watch the word WRITE flash from green to red or you won't save your adjustments.
Jan 07, 2010 | Sony FD Trinitron WEGA KD-27FS170 TV
My Sharp Aquos TV Model LC-30HV4U (1) has a large black triangle in the middle of the TV screen, and (2) the letters of words that appear on the screen are in reverse order and so are illegible.
if you the reset option once you try resetting ...
if you still persist the problem i think there will be some problem in the tube in that area ...
Sep 05, 2008 | Televison & Video
Pincushion like problem
You did not mention that this cost any money, so I assume that this was a warranty repair. There is the possibility that the new light engine is defective (I see it all the time), or TV needs adjustment via service menu, not mechanical. Call company back or call manufacture to get another company in your area to come out and repair your TV properly. Don't quit until your TV is working properly. Good luck.
Feb 21, 2008 | Zenith E44W46LCD 44" Rear Projection...
Problem with monitor
Your post/description indicates a "pincushion" problem; the width problem is as you have stated.
There are two (2) possible reason for these problems:
1. component failure in the horizontal section of the monitor. These components could either be a diode, a capacitor or a resistor. In some cases there are trimpots in the PCB that can be adjusted to correct these problems;
2. component/connection failure in the controller section.
Of the two, I tend to suspect #1 as highly likely the case. Repairs such as this would require that you be familiar and comfortable working with electronic components and circuitry, the use of a DVM and a soldering iron. Should this be not to your liking, your next best bet would be to seek the services of a qualified professional.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 03, 2008 | HP Compaq FS7600 17" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Have you ever had this problem?
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
LG 30FZ4D TV Logo
449 people viewed this question
Ekse
