Question about HTC Touch HD Smartphone
When placing a call on HTC diamond tomtom 7 opens
Ok i have tried everything to figure this out. I press the call button to place a call, when i dial all is good. now when i press send and the call begins the phone starts the tomtom app. kinda a pain when i need to input additional numbers for a mail box or such..is there a way for tomtom to notbe opened..did the same thing on my htc touch 6900
    President:
  • HTC Master
  • 782 Answers
Check the directory where is tomtom installed. it should be on main directory on memocard.
Posted on Aug 25, 2009
SOURCE:
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
I HAVE A HTC TOUCH DIAMOND. WHEN I TURN IT ON IT DOES NOT START UP IN PHONE MODE. THE SCREEN COMES UP WITH A RED,GREEN,BLUE AND WHITE BANDED SCREEN WITH DIAM130 64M SPL-1.38.0000 MICROP-DIAM (LED) V11 IN...
Looks like you should try to Hard Reset it.
This is done by having your HTC Diamond turned off first.
Then, hold the VOLUME UP and DOWN buttons at the same time and briefly press the POWER BUTTON.
Now keep holding down the VOLUME UP and DOWN buttons until you see a screen
At soon as you see this screen, you should release the VOLUME UP and DOWN buttons.
Now press the VOLUME UP button to complete the hard reset. Now this will completely format your HTC Touch Diamond as if it was turned on for the first time from the box. Everything once previously on the phone will be deleted including messages, contacts, music and the like. Hope I have been of assistance to you, Cheers :)
Apr 23, 2010 | HTC Touch Diamond Smartphone
I have formated my tomtom one and know it will not start with out showing a flashing disk and a x
Probably the last update was not applied correctly or it was corrupted.
Please, try this:
1) Place the GPS on the cradle connected to the computer and start TomTom Home.
2) Turn the GPS on and connect it to the computer.
3) Erase the downloaded software (using the "remove items" from the TomTom home software)
4) Choose "disconenct device" from the drop down menu of TomTom2_bing.gif Home
after the GPS powers down and restarts, press the RESET button on the button (keep it pressed for 7 seconds)
5) Repeat setps 1-2 from above. When TomTom Home detects your GPS, it will offer to update it. If it doesn't, choose "update device" from the TomTom Home buttons
Please, report back if you need further assistance
Mar 28, 2010 | Tomtom One XL GPS Receiver
How do I install toomtom 7 on SD card on my HTC Touch Diamons 2? When I incert the SD card the phone gives message tomtom not compatible
Hi, you can install Tomtom 6 on your device but you will need to contact Tomtom themselves to get a new registration code as the device ID will be different, they allow you one change every six months.
You will need to install it from the CD or copy the contents of the original SD card onto your Diamond, I Hope that helps you.
Mar 23, 2010 | HTC Touch Diamond2 Smartphone
I have a HTC Touch Diamond and it turns off when I place a call and restarts
try hard reset, just press reset button while holding volume down and enter (circle button in the center), do not forget to backup your phone, it will erase all your settings and programs and phone memory (you could select, if you want also internal memory)
Jul 06, 2009 | HTC Touch Diamond Smartphone
Default password
Do a hard reset, hold down the power button, volume down button AND the ok/enter button. At the same time press the reset button in the back of the diamond (under the cover). Keep holding the buttons, other than reset, until you get a message giving you further instructions to hard reset.
This will erase all settings and programs.
Feb 09, 2009 | HTC Touch Diamond Smartphone
Take picture from HTC Touch Diamond phone
you open camera application now swipe yor finger across the hard keys to enable / disable auto focus. now when you find a nice picture you want just press the area on the screen you would like to capture after a second the picture you have taken will appear.
Jan 19, 2009 | HTC Touch Diamond Smartphone
Wifi Dosn`t Turn on
Try a soft reset, its under the back cover.
If that doesn't help, do a hard reset, press the power button, volume down button, and the ok/enter button. At the same time press the reset button in the back. Keep holding all keys down (execpt reset) until you get a message on your screen giving you further instructions.
If you installed 'modification' programs that add a function/feature that changes windows mobile settings, or your data connection, etc. Try uninstalling it, and don't download it again unless you know it full supports your diamond (there and different versions of the diamond as well to make a note of)
Jan 18, 2009 | HTC Touch Diamond Smartphone
The speaker does not work properly.
Try a hard reset, press power, volume down, and enter/ok/center button, all 3 at the same time, and while pressing those down, press the reset button in the back down. Once it reboots, you can let go of the reset button, but keep holding down the other 3 until you get a message asking you to revert to manufacturers settings.
This will erase all data and settings, so make sure you backup your files (and use ActiveSync to sync contacts to outlook, to make a backup of contacts).
If this doesn't work either, then if you have the warranty, send it back to HTC to get it looked at.
Jan 09, 2009 | HTC Touch Diamond Smartphone
HTC Touch HD Smartphone Logo
152 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
