Question about GE JGRP17 Gas Single Oven
GE True Temp Oven Timer Instructions
How do you use the timer?
  • 10 more comments
  • terric Dec 16, 2007
    Not sure how to keep the oven on.  It beeps after a certain amount of time.  I was left without a manual.  Terri
  • Anonymous Nov 15, 2008
    My True Temp oven was in the middle of cleaning when it started beeping and flashing F2. What does this mean. i immediately turned off the oven but the beeping comes back every two minutes.
  • Anonymous Nov 22, 2008
    How do I get my oven to stop beeping and displaying F2?
  • Anonymous Nov 30, 2008
    Yes, I have the same problem with our GE True Temp Oven. We set the self cleaning function and mid way through its cycle the F2 light flashed on and the oven kept beeping every 2 minutes. We've lost our manual as well so we're at a loss on what to do.
  • kevin177 Dec 05, 2008
    FO light keeps flashing and oven timer beeps every two minutes or so. what's the deal?
  • Anonymous Dec 24, 2008
    my oven keeps beeping in self cleaning mode and the display is blinking f2. what does it mean?
  • cthomastrain Jan 12, 2009
    Did anyone get the answer to the F2 issue with the GE oven cleaning? It keeps beeping not sure how to fix.
  • Anonymous Jan 20, 2009
    My oven is beeping F7 does anyone know how to turn it off or what F7 is
  • Momofive Jan 28, 2009
    during self clean mode f2 display and continuous beeping
  • Anonymous Apr 03, 2009
    F-7 code
  • Anonymous May 13, 2009
    my oven has a fan that blows outside the oven.is that normal.it seems a little warm.it stays on while cooking and the after the oven is turned off, it continues untill the oven cools
  • Anonymous Mar 31, 2014
    ge true temp electric oven
  • 25 Answers
Go to this web site put in your model number and you can download the whole use and care manual http://www.geappliances.com/ just look for the search box half way down on left select use and care then put in the model number
Posted on Feb 23, 2008
    New Friend:
Thanks will give it a try .
Posted on Jan 19, 2015
GE JKP26Gop2bg
If the oven is 23 years old, it could be time to replace it.
May 20, 2017 | GE Ovens
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
I have a GE electric oven mode JSP48G*J2. It has a mechanical clock/timer that has gone bad. The replacement part is WB19X10007, but I'd like to see the instructions for installing this before I go spend...
Normally the mechanical timers have only 2 terminals. Active supply in and oven load out. It doesn't matter which wire you put where. If you don't use the timer just join the active supply and the load together and the oven will work.
Feb 15, 2011 | GE Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
GE JGRP17 Gas Single Oven Logo
13,947 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
