Question about Nintendo Wii Console
Scratching disks It appears that my wii console is somehow scratching all of my disks.  All of my games have several scratches that go around the outside edge og the disk.  I even tried with the last two games that I purchased being very careful about taking it out of the game box and putting it away carefully.  Still the scratches appeared after about one month of use.
  • salsweep Feb 02, 2008
    my wii console scratches the middle of my disk, I have a circular scratch mark going round the middle of the disk. it started this week has damaged two disks, which will not longer play. and have stopped using the console, I need to get the problem fixed or console replaced, but I am not prepared to pay for it, I have only had the console since july 07.
    President:
  • 4,402 Answers
Http://www.nintendo.com/consumer/systems/wii/en_na/ts/gameDiscReplacement.jsp
Posted on Dec 13, 2007
When I insert a disk, the system makes a rumbling noise.
Posted on Dec 14, 2007
SOURCE:
How do you fix a wii u game if it keeps saying invalid disc every time you clean it
First make sure it is a Wii game. Try another disc to make sure the console is working properly. If the disk is scratched, get yourself a scratch repair kit for DVDs. When you clean a disk, make sure it is dry before inserting it in the console. Good luck!
Dec 22, 2016 | Video Game Consoles & Games
My brother just wrecked most of my discs for the wii but some of them are fine and the same message is popping up. and i noticed the scratches are in circles around. could it be the wii scratching the...
it could be your wii,but if you were to clean a disk use tooth paste and gently rub it on the disk up and down. never clean a disk in a circular motion. or go to a game store and ask if they can clean the disk. or buy scratch out. can be found at a block buster. hope this helped. :)
Sep 08, 2011 | Nintendo Wii Console
When a disk is inserted, error message says "unable to read disk".
You might either have inserted the disk the wrong way, flip it around. Or the disc is scratched/dirty The Wii might not also recognize the CD.
Hope this helps : )
Dec 31, 2010 | Nintendo Wii Console
Wii can not read disk
Disk may need cleaned, try cleaning with a slightly damp cloth using a light detergent, never use Bleach's or other strong detergents as they may damage disks. Also you can check for scratches, I personally use Skip Doctor to remove scratches from my disks.
Jun 01, 2010 | Nintendo Wii Console
My Wii keeps saying "unable to read game disk". It is a new game with now scratches.
the lens may be bad or needs to be cleaned.is the machine scratching the disk.if so there maybe some kind of foreign object or a broken piece of plastic inside the machine.
Jan 24, 2010 | Nintendo Wii Console
When i put game in comes up disc error what do we do
If the problem exists with all disks, your problem is with the disk drive itself. Wii disk drive cleaning kits retail less than US 8$ and are your best solution in this case. They include a custom sized microfiber tool used to clean the laser reading lens inside your Wii disk drive. If you have trouble with just one disk, the disk you are using may be dirty, scratched, or defective. Try cleaning your disk with water and a soft cloth (Do not use a paper towel, it will just leave paper pieces on the disk.) If the cleaning does not help, look for scratches on the top AND bottom of the disk. The slightest scratch on the disk can cause a read error. If you have a scratch you can try a disk buffer. Some video and game rental stores offer a disk buffing service for a small fee, if buffing and cleaning do not work, your disk is most likely defective. Return the game to the store you purchased it from and ask for a replacement if possible.
Dec 31, 2009 | Nintendo Wii Console
The console is not reading several games that it used to read.
Sometime the inside could be dusty try to get one of those pressurised air gun dusters and spray inside the disk slot. sometime the inner ring of the disk were the system variefies its a wii game could be slighly dirty so clean mainly around were the hole is in the disk.
Jul 18, 2009 | Nintendo Wii Console
A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
Jan 02, 2009 | Nintendo Wii Console
Circle scratches on wii games
(For Quick Solution Read All Caps) I Did Also... you need to remove the ga,es from the after playing... and if you stop playing the wii take the disk out... the wii keeps reading the disk no matter what you are doing so... simply put:
TAKE THE DISK OUT IF YOU ARE NOT PLAYING IT
Dec 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
219 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
