Question about Acer TravelMate 2300 Notebook
Travelmate 4000 Working OK, then switched off. When turned on again nothing appeared on screen. Any ideas.
  • Anonymous Mar 06, 2008
    Any ideas.
I had a similar problem and found that after the powerdown it would not restart... it turns out that the power socket was brken and I had been running on Bat power and once I had turned it off the bat no longer had power to start thr laptop up.. annoying.
Posted on Jul 06, 2008
It doesn't work:S
Posted on Mar 18, 2008
It doesn't work:S
    Sergeant:
  • 324 Answers
See that you seem to have 2 postings on this. If not, the advise is the same. Power down, remove the memory module(s), reseat the modules and power back up. If this didn't do it, getback to me and we shall continue on. ;o)
Ron-
Posted on Dec 02, 2007
Power botton flash and no start
check your ram.......via system info...
Jan 29, 2014 | Acer TravelMate 4000 Notebook
My travelmate 4000 has been infected with a viirus. I want to re enstall window but i dont know how as I'ts on the comuter..is there a way
You will need a Windows CD, which i think came with your laptop. Insert the CD and follow the instructions on-screen.
Best regards
May 08, 2010 | Acer TravelMate 4000 Notebook
I have acer travelmate 290 while working suddenly the screen went white and the remained so i turned it off and now i try to start it power comes on but display shows nothing. tried removing HD and Drive...
I have the exact same problem with my old computer! The problem started after I switched the HDD a long time ago but I never got it (semi-)working again until a few days ago.I completely disassembled the computer and reassembled it again and I finally got something on the screen. I the tried to install win xp but when I pressed the keyboard the problem reoccurred. Therefore I'm fairly sure there is a short circuit or a bad connection somewhere probably on the underside of the motherboard close to the power supply DC-connector.
Apr 10, 2010 | Acer TravelMate 290 Notebook
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
My Travelmate 290 series is not working...
Try taking the memory out and then put it back in making sure it seated correctly then start using AC power lead it's probably caused by letting the battery get too low before recharging.Use a start up disc to get it going if you have to. Good luck
Aug 02, 2009 | Acer TravelMate 290 Notebook
Need help using Recovery CDs on TravelMate 290
run the command rstrui.exe to restore the system if it does not work only way is to reinstall os
May 08, 2009 | Acer TravelMate 290 Notebook
As a temporary fix for my Acer 4000 travelmate cracked screen I have connected a 15 pin cable from the back of my laptop to my sony Bravia TV. When I switch the TV to the PC extenal input page the words...
Usually its a combination of the Fn key and another key...it should have a picture of a screen on the key in the same color as the Fn key....usually it's F4.
Thanks and please take a moment to rate this solution as fixya.
Mar 14, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Blank Screen
May have a real quick fix for you.
Power off, remove the memory module(s). Reseat the memory modules, and see if it doesn't come up for you.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 02, 2007 | Acer TravelMate 2300 Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
