Question about Acer TravelMate 2300 Notebook
Blank Screen Travel Mate 4000 working properly, running AOL, then logged out and shut down on windows XP normal shutdown procedure. When started approx 1 hour later, screen stays blank as if not switched on. There are the usual drive warm up sounds but only for about five seconds. Connecting to PC monitor has no effect. Any ideas
I have the same problem with my Acer Travelmate 4000 and this suggestion doesn't help....can u suggest something else??
Posted on Jan 21, 2008
    Sergeant:
  • 324 Answers
May have a real quick fix for you.
Power off, remove the memory module(s). Reseat the memory modules, and see if it doesn't come up for you.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Dec 02, 2007
SOURCE:
Laptop doesnt shut down
With xp you a have to select
Start --> the right arrow --> then shutdown.
Aug 27, 2012 | HEWLETT-PACKARD HP ProBook 4420S NoteBook...
Acer Travel mate 7730 os xp laptop shuts down
make sure processor fan is working fine. you may hear the sound of fan on the left side of the laptop. and make sure its not getting heat soon. If the fan is not working you need to replace the fan. If if gets heat soon that means you have to put processor cooling paste.IF the fan is working fine and the processor heat is normal, then you need to re-fix the RAM. Then it will work fine..ok
Jan 26, 2010 | Acer Aspire 3100 Notebook
Window not working properly
You need to find right drivers for your laptop .
search on google as " windows drivers for acer travel mate 5520 " if you do not know how to install drivers let me know .
scan you system with an anit virus as well
Oct 31, 2009 | Acer TravelMate 5520-5929 Notebook
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
I have a laptop acer travel mate 2310 and if i press start it comes on and shutdown immediately.
u have shut down virus in your pc u have to do this go in start>run>
type in run shutdown -a & your problem will slove
Jan 12, 2009 | Computers & Internet
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
Desktop is blank white
The problem can be solved by reinstalling windows vista.
Oct 24, 2008 | Microsoft Windows Vista Ultimate Edition
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Nov 09, 2007 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Ekse
Alun Cox
