Question about Kenmore 15864/15862 Top Load Washer
Smoke smell coming from my 80 series Washer
I recently replaced the motor coupling kit, and it is working fine, but now I notice some smell (smoke?) during the end of the wash cycle as the water has completed draining. The smoke seems to come out of the tub when I lift the lid. Everything else seems fine, MDL# 110.28812790
Thanks for your help.
  • rg01 Jul 03, 2008
    I have similar problem, real smoke, not just smell, on my Kenmore Model #110.26932691. After I had a handyman replace Motor Coupling (which fixed the not-spinning problem), I ran a full wash cycle. Smelled something during spin right after wash cycle. When I opened lid, lots of "smoke". Not like electrical burning, more like very fine dust, smelled hot, but not actual burning. Suspect brake or clutch didn't release and stayed engaged, but not sure how to verify or fix.
  • Anonymous Apr 08, 2009
    Replaced a coupling now my washer makes smoke too...
    There is a connection between the coupling and the smoke - it's not detergent related.
I have a hoover amc121 washer when its done its final spin and the door is open there is smoke comeing out of the drum,im guessing the heater is staying on.it could be a problem with the preasure switch,anyone else got any ideas on this
Posted on Mar 08, 2008
  • 105 Answers
Do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Posted on Jan 28, 2008
My wife noticed smoke right after starting the washer. She immediately turned it off and called me. I noticed a smoke smell which smelled more electrical than rubber. The basket spins easily. The washer...
Thanks for choosing FixYa and welcome to the site. There are a few things that you can check. First, check your belt. It may have worn or the pulley may be sticking. The belt may be causing the smoke. You might want to check your control board just in case and see if you see any damaged wires. You need to try and see if the washer throws out any error codes. I really don't know what else you could check because there are no symptoms. It could have come from the water pump or the motor drive also.
Apr 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Smoke and electrical smell coming out of motor
Sounds like your "brushes" will need to be replaced. Please see the attahced video for step-by-step instructions.
http://www.youtube.com/watch?v=tECeZi6IfvU
Mar 05, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a Kenmore series 90 washing machine, Model 110.26902691. I changed the motor coupling last week and after being proud of my work, I was able to complete one cycle before I started to smell a burning...
Considering the info you`ve provided, specific to the history of replacing the drive coupling. You stated that right after replacing the coupling it started to smoke or as you said "I started to smell a burning smell". Can you identify if it was electrical, or was it rubber/plastic ?
I`ve seen these coupling`s when not put on correctly start to rub against the motor or the transmission, you might want to double check your work with installing the coupling.
Aside from that it could possibly be the motor, but if it agitates and manages to advance through the wash & rinse cycle up to the spin, I`d be skeptical of a motor problem. You should check to make sure the lid switch is being fully closed, in the event it isn`t closed properly the unit will do everything except spin.
Hope that help`s. Good luck.
macmarkus :)
Dec 08, 2009 | Kenmore 24902 Top Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Ford Focus 2000 Smoke coming from Motor
no ohter reason for smoke comes to mind under the hood
sounds like maybe the valve cover gaskets 20 to 30 dollars here in canada
not very hard to replace take off the valve cover take out old gasket clean the area good and put new gasket in tighten valva cover down usally untill you see the gasket compress a little being carefull not to tighten to much and either break a bolt ot strip it
Feb 28, 2009 | 2000 Ford Focus
Strong electrical smell with smoke coming out
Check the lower motor control board. See www.neptunehelp.com for disassembly pictures. It is possible you will need to replace the motor control board and motor if you have the original one as Maytag has redesigned these two components due to reliability issues. The new motor conversion kit is part # 12002039.
If there are any burnt components on this board then it will have to be replaced. There is also a 10 amp fusesoldered to the board. if this fuse blows the tub will not move anymore and the motor control board / motor will have to be replaced.
Have you noticed your Neptune's spin cycle getting loud? If so, the seal kit and bearings need to be replaced. See www.neptunebearing.com for more info on the special bearing tool kit you can rent that includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Feb 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Burning Smell
no check wiring connector at the motor and the capasitor connectoions, lid switch connections
May 10, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
1,593 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
