Question about Husqvarna Viking 1
Husqvarna Viking #1 blown fuse
I need to know where I can find the computer boards for a Viking #1. Husqvarna will only supply the needed part to an authorized Husqvarna repair place, not another repair shop not theirs. I have dealt with their dealers, incompetent, want to use a Bernia repair place as their technician is really good. IThe machine keeps blowing the fuse, like amp. but not specifically for that machine. Suspect the board has a short in in but still want to find somewhere to buy the board, and not have to take it to the local Husqvarna repair. They don't know what to do and will just tell me to buy a new machine. Knowing this, it will not be a Viking even thought I like the machine.
  • 1 more comment
  • mamaroo Dec 19, 2007
    My Platinum 770 will only sew a straight stitch. Nothing happens when I choose another stitch pattern. Also the stitch pattern information on the screen shows incorrectly. Do you think that the computer/circuit board has gone out?
  • Anonymous Mar 24, 2008
    I TRY TO UPDATE MINE AND THE SCREEN GO BLANK WHAT I CAN DO
  • afelkey Feb 16, 2009
    Touch screen on our Designer 1 does not respond. It lights up and displays the stitch screen but does not respond to touches. Any thoughts?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 87 Answers
Contact Ron at A1, he sells Husq Viking and can even email attach a PDF parts list to you.
http://www.a1sewingmachine.com/parts.html
Posted on Apr 28, 2008
You will most likely find that ALL of the "better" manufacturers; Bernina, Husqvarna, Pfaff, will not sell proprietary parts to non-brand dealers. Ultimately, this protects the customer.
With that being said, chances are the problem you are having is NOT a bad circuit board, but a bad power supply. But, since you don't trust your local dealers, find a dealer that is not so local. A two hour car ride is going be a lot cheaper that replacing the wrong part, and NO dealer will return your money on a part that the customer diagnosed as being faulty. I assure you, a Viking dealer somewhere will help you with your problem. You might want to try a Pfaff dealer. They can sometimes obtain Viking parts.
I would try replacing the power supply first. Its a cheaper priced part, and more likely your problem. Its also easier for DIY'ers, but extreme caution must be taken to ground yourself to the machine. Static is always a concern with electronic sewing machines, and even more so this time of year. Proper grounding equipment should be worn while performing any internal repair or adjustment in any electronic machine.
As far as replacing the circuit board yourself, if necessary, also be very careful when disconnecting and reconnecting wires. The connectors are very small and bend easily. Also, care should be taken when tightening screws. Overtightening can cause faults within the circuit board by cracking the solder paths or just plain break the board.
Posted on Dec 04, 2007
SOURCE:
Is there a replacement fuse or power supply for Husqvarna Viking 990??
check with husqvarna customer service about the fuse or power supply
Feb 27, 2012 | Husqvarna Sewing Machines
My Husqvarna Rose is dead. My husband tried to replace the bulb and it was the wrong one and it wont turn on at all. IS this too a fuse. Where is the fuse on these machines
You can check inside the power supply unit for a fuse, but I think he probably blew a voltage regulator and the power supply will need to be replaced. Contact an authorized Husqvarna Viking repair center.
Dec 13, 2010 | Husqvarna Viking 1
I have a viking 1100 sewing machine that the power will not come on
Either the fuse in the power supply unit has blown or your main circuit board has failed. Take it to a service person for a diagnosis.
Nov 15, 2010 | Husqvarna Viking 1
Viking sewing machine 940 needs spare parts circuit board and ballance hand wheel
Certified Viking parts are only available from an authorized Husqvarna Viking dealer. However, there are some third party parts companies online. You should be able to find these using Google Search. However, I strongly recommend you have the machine serviced through an authorized Husqvarna Viking dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 09, 2010 | Husqvarna Viking 1
I need to buy a new speed controller for my overlock sewing machine. Husqvarna Viking Husky Lock 905 any help pls. i need to know how much will it cost me and if it is possible to ship to Malta, Europe.
Should not be a problem to ship internationally. Contact an authorized Husqvarna Viking dealer. They should be able to order one for you and give you a price before ordering. Also be sure to tell them the power requirements in case it is different from the USA/Canada. Check Husqvarna Viking website for dealer closest too you.
Sep 13, 2009 | Husqvarna Viking 1
Looking for stitch cassettes for Viking 1+ -
Check with your local Husqvarna dealer. They are easy to save even if an old machine has been thrown away. Many dealers will have a supply of used cards.
Sep 04, 2009 | Husqvarna Viking 1
Dead battery
There is no battery in a Viking #1. If you have no power it could be your transformer. There is a fuse on the transformer, so it may be serviceable. You need to remove the circuit board in the transformer to see the fuse so a trip to your service tech is needed
Aug 26, 2009 | Husqvarna Viking 1
I was trying to change the stitch setting on my husqvarna 400 sewing machine, and it seems like the panel does not respond to anything that i touch. the machine does not even go into reverse. Is the...
It could be the touch panel or the main board. The touch panel ribbon connector could be loose but not likely. Needs to be diagnosed by a good tech. for Viking.
Jul 18, 2009 | Husqvarna Viking 1
Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
Mar 26, 2009 | Husqvarna Viking 1
I have a Husqvarna Viking Sewing Machine and I cannot figure out how to thread it! Or do anything for that matter. Any help would be great.
Try ebay or contact an authorized Husqvarna Viking dealer. They should be able to order you a replacement manual. Check Husqvarna Viking website for dealer closest too you.
Jul 08, 2008 | Husqvarna Viking 1
Sewing Machines Logo
1,426 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
