Question about Philips Magnavox 51MP392H Rear Projection Television
Picture problems I have a magnavox 51MP392H rear projection telivision that I bought three years ago. It has worked fine until last night. I was watching the set and all of the sudden I have double print in the top right and lower left corners. The double print is in blue. I went into the manual convergence menu and tried to adjust but those corners wont adjust. help
  • 3 more comments
  • bathman Dec 02, 2007
    how much are we talking about to fix it?
  • Anonymous Dec 03, 2007
    I have the same problem, so let me know too. mine is two years old and and it just started doing it two days ago. I haven't touched it yet
  • golfsharky Dec 04, 2007
    i also have the same problem but my unit is almost 4 years old
  • kagemusha Dec 07, 2007
    Mine also has this problem. We had it on in the morning and all was fine and came home a couple hours later and red wavy picture in the bottom and the corners. Looks like a 3-D movie without the glasses.
  • Anonymous Dec 11, 2007
    Hi I have the same problem as well with my 55 inch which is 4 years old and the techs have told me it's something to do with the convergance modules and will cost around $400 to $500 if I take it to there workshop.
  • 934 Answers
The convergence amps have most likely failed. This is the number one leading cause for the symptom your describing and the most common failure on that unit.
Your Tv take two STK392-120 Sanyo Ics for convergence amps, located at Ic7404 and Ic7405 on the board and mounted to a rather large aluminum heat sink. In addition you will most likely have to replace R3159 and R3160 (6.8 ohm 1w) resistors and test the remaining low ohm resistors for change in value.
A shop would really be earning their money on this particular unit if they charged $400 - $500 for the repair. It is an extremely difficult set to work on and there are a number of little problems that can reach-out and bite when attempting the repair.
Posted on Dec 12, 2007
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
How do I get to the bulbs to clean them? I have a 65 inch flat screen rear projection tv which I purchased brand new about 8 years ago.
Unplug the TV.Remove the back cover.Gently wipe the three guns and the white screen.Reasssmble.By the way vacuum the chassis while you there
Oct 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
if you bought it under one year ago then the retailer should be obliged to either replace it or repair it. I would look into this further, ask to speak to the manager or something casue when a tv switches itself off it indicates an error inside and turns itself off to prevent further damage.
Jan 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
No power to tv
power supply or power supply relay
Sep 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
52" philips magnavox
theres focus controls inside the rear of the set on a small control panel with 6 dials 3 control the screens, and the other 3 control the focus for all three tubes.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
