Question about Ovens
Kenmore electric oven
I set bake temp at 350 and once it reaches the desired temperature a f4/f8 code comes on
  • 1 more comment
  • ejschool Dec 31, 2007
    I have the same problem the burning element does not heat up and I get the f4 error.
  • tistie Jan 17, 2009
    My GE TruTemp electric single oven heated up to 350 and shut off, but the time works. An F7 show on the control panel. Have installed two complete control panels, but continues to do the same thing.
  • Anonymous Mar 31, 2014
    What temperatures are each of the following settings; media, dorar, hornear, and maximo? I know what the words mean in english but I don't know how hot each setting is. I need to know the actual temperature for baking purposes. Thanks!
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired cook. Can you tell me what my problem is? Thanks. Doug.
Posted on Jul 20, 2008
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
I have a Kenmore 790.95660100 and the stove will not turn off. Once we select bake it begins to heat and does not shut off when it reaches the desired temp.
Sorry to read about your problem, I hope this helps you out.
you may have a defective temperature probe.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Top element doesn't get red hot on bake but does on broil is my controler bad
The top element (broil element) will come on when you put it in bake only to help the oven temp get to the desired setting. If your temperature is reaching the right degrees you shouldn't have a problem.
Nov 02, 2010 | Kenmore Ovens
When baking a cake or bars the oven is set to the recommended temperature and baked for the recommended time and the middle doesn't bake all thru.............gooey.
Put a thermomiter in the oven and set oven to 350. Once oven says it has reached temp. Give it about 15 min and check the thermomiter you placed in the oven to see if it maches.
This is where I would start.
Jan 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Jul 19, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
666 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
