Question about IBM ThinkPad T20 2647 Notebook
T20 how do you remove the cd/dvd drive from ibm t20 thinkpad
    Sergeant:
  • 324 Answers
Good afternoon Lewis!
Close to the right rear corner, there is a small black plastic latch that needs to be moved to the rear. That will cause a blue handle to pop out slightly. You grasp that handle and pull. That should release the CD drive and allow for it's removal.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Dec 02, 2007
How do i install operating system with external dvd
Hi
How to Install Windows XP on a Thinkpad T20
The Thinkpad T20 is a laptop computer from IBM designed for business use. This computer comes with the Windows XP operating system and--if necessary--can be reloaded with the operating system. All you need to perform this operation is the installation disc for Windows XP and a valid product key. This product key can be found on the bottom of the computer or with the documents included with the machine (if Windows XP was pre-installed on the computer).
Windows XP CDProduct key
1 Turn on your T20 laptop computer and press the blue "ThinkVantage" button.
2 Scroll through the options and select the option to boot from your T20's CD/DVD drive.
3 Press the "Enter" key at the welcome window and press the "F8" key once you have read (and agreed to) the license terms for installing the software.
4 Select the drive on which you want to install Windows XP and press the "C" button, followed by the "Enter" button.
5 Press the "Enter" button again to start the installation process. When prompted, enter the product key for Windows XP. Once the setup finishes, you can use the computer.
Dec 26, 2011 | IBM ThinkPad T20 2647 Notebook
ThinkPad T20 2647 PC Notebook: The lap top will not boot. It's a thinkpad T20...
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
May 17, 2010 | IBM ThinkPad T20 2647 Notebook
Can Windows XP Pro be installed on an IBM T20? I'm
yes you can. I checked e-bay and there are lots of them with windows xp.
Sep 09, 2009 | IBM ThinkPad T20 2647 Notebook
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Need driver for 8x dvd drive for thinkpad
When a properly inserted and working drive is connected, it is automatically discoveredand installed. Specific drivers are not necessary or available. I will assume you are not talking about a DVD viewer application?
If the OS does not discover the drive, then the drive is likely defective, or not properly connected.
Oct 26, 2008 | IBM ThinkPad T20 2647 Notebook
Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Jun 27, 2008 | IBM ThinkPad T20 2647 Notebook
T20 Laptop will turn it self off
Failing or clogged fan fan is a good possibility. Fans are cheap on ebay for those and easy to install (2 screws underneath the laptop to remove the keyboard and 3 for the fan assembly itself. I would pull the keyboard and check for dust then replace the fan if that doesnt help.
Dissasembly guide for t20-t23 is online here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-4UYM3F.html
Jan 10, 2008 | IBM ThinkPad T20 2647 Notebook
DVDROM T20
Hello again, Lewis!
I take it that you got the CD unit out of your laptop?
If you would be so kind as to sent me the FRU number, or exactly how it is labeled (such as "CD-RW/DVD") I should be able to provide what you are looking for.
Thanks!
Ron-
Dec 02, 2007 | IBM ThinkPad T20 2647 Notebook
Install hard drive for t20
So, what is it you want to do?
The hard drive on a T20 is in a slot on the left side of the unit, and it's cover can be taken off by removing 1 screw on the bottom just under the sound ports.
Hope that helps.
Nov 25, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
85 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
