Question about Magic Chef CGR3725 Gas Kitchen Range
Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
We have a magic chef gas oven. Lately it has been heating up slowly with an intermittent smell of gas through
the entire cooking cycle.
  • 3 more comments
  • jamesn67 Dec 03, 2007
    Yes, we aren't using it. Gas makes me nervous but thank you for the warning.
    I appreciate the response as well but I think I'll just call in a service to do it so I don't screw it up.
  • kelso07 Dec 23, 2007
    My Magic Chef 31GA-3KX gas stove also started giving off strong gas fume odours after starting the burners and or oven. Does not appear to have any blockages or buildup around the burners though - could this be a faulty pressure regulator valve?
  • Anonymous Mar 13, 2014
    Oven does not get hotter than 200 degrees
  • Anonymous Mar 16, 2014
    magic chef oven codce f3
    how to repair f3 code on magic chef oven
  • 833 Answers
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Where is the oven pilot?
Hi lift out the bottom panel on the base of the oven it should be under there
Jul 17, 2009 | Magic Chef CGR1425 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Build in Over Gas - Oven does not heat
I called a repairman it was the igniter.
Jan 26, 2009 | Magic Chef 9122 Gas Single Oven
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Leak Safety Valve Magic Chef Oven?
that could be rigth only if that ignitor is good,,,that ignitor has to glow bright orange,,if its weak,,which it sounds like to me,,the gas will take a long time to ignitor,,or dont ignite and you smell a wee bit of gas,,,onthejob
Jan 08, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Sep 27, 2007 | Ovens
Magic Chef CGR3725 Gas Kitchen Range Logo
923 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
