Question about Mitsubishi VS-50609 50" Rear Projection Television
Can hear tv 'click' on w/no power l.e.d., pic or sound.After ~5sec. it 'clicks' off
Can someone help with schematics or info? Thank you.
    Genius:
  • 1,139 Answers
The click you are hearing is the shutdown relay activating. This is a sign that there is an excessive current drain in the TV. The current drain causes the shutdown circuitry to activate. I would suspect the SMPS as the cause.
Thank you,
Shuttle83
Posted on Dec 21, 2007
SOURCE:
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Locks up when loading a game
locks up usually means a corrupt file. GO into safe mode
1. hold power button down til powers off then hold again to power on continue to hold 5sec will hear a beep 5sec again another and it will power down.
hold it again 5sec hear 1 beep then about 2-4sec later 2 quick beeps let go of it. You will be asked to plug your controller in.
from the options in safe mood click the restore system files option it will tell you your hard drive is corrupt just click okay it will do its thing restart and you should be good to go.
Justin
Apr 26, 2010 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
I hear a sound like a shortcircuit on backside?
I think the problem is either the power supply/High Voltage board or the IHVT (Integrated High Voltage Transformer). I don't have schematics for this model, in addition you will need to take the IHVT out and perform a ring test on it, also I would advise you to check and see if the Horizontal Output transistor is shorted also, you can do this with an ohmmeter (measure between the collector and ground it should have a high reading if the reading is low the transistor is bad). The ring test can be performed with the use of a Universal Video Analyzer, or a LCR analyzer.
I hope this helps,
Thank you,
Shuttle83
Jul 18, 2008 | RCA P46921 46" Rear Projection Television
Sony TV Problem model # KV-27V42
your tv has a  short  circuit, the power supply see that and put away the polarizatio n , you have to check  if transistor of power on flyback transformer is  good
or bad - delfo
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
No sound no pic!
That is the DPTV310 chassis I believe the problem could be in the power supply input board or the large signal board. I have a source to locate those boards used if you would like me to post it. They sell parts cheap and all parts are in good working order. I have used their parts many times.
Feb 23, 2008 | Philips 55PP9352 55" Projection Television
RCA projector HD65W140
It sounds like you have a real bad problem, Do your Circuit Board looks repairable? Was the burn thru the board? Are you saying you need the schematic for this TV? For more info ctechnicians.com
Jan 07, 2008 | Televison & Video
Mitsubishi VS-50609 50" Rear Projection Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
