Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Freezing Upon Log-In attempt
I can plug my external hard drive in, the computer recognizes it and autorun comes up. It asks me for my password and when I go to log in as soon as I click "log in" it seems the program stops running and the light periodically flashes red (unless I'm mistaken it usually will be pink/blue, not red). Is this a software issue? If so is there any way to fix it without losing my stored information or having to send the hard drive back to get fixed? I'd prefer not to have to wipe the hard drive.
  • 871 Answers
Red usually means that reading has encountered an error or that it has encounter a corrupt file thats why it freezes. try to recover those files using recovery software.
Posted on Mar 24, 2008
SOURCE:
Iomega prestige portable hard drive
What are you trying to do ?
You can use any drive as long as you have usb or other required ports available on your computer.
If an external hard drive on your computer has been locked, it has likely been done by the computer's system administrator.
This means that anytime you try to access the drive, you will be prompted to enter either your password or the administrator account's password (depending on the methods that person used to lock the drive).
If it asks for the administrator's password, you can't unlock it until you get that information from the administrator.
Click the Windows-logo button on the lower-left-hand corner of the screen.
Click "Computer."
Double-click the icon for the locked external hard drive.
As Windows Explorer attempts to access the drive, it will recognize that the drive has in fact been locked and you will be prompted to enter a password.
Enter the drive's password into the box and click "OK" to view the contents of the locked external hard drive.
Aug 14, 2013 | Computers & Internet
Tip
Make ESET NOD32 Anti-Virus Auto Scan Flash Drive
Everyone doesn't want computers infected with a virus. The question is, where the virus entered into the computer. There are two possibilities, may be infected from the Internet or external device (flash drive, memory cards, external hard drives, etc). Flash drives are external devices that are often used. When we insert the flash drive to the infected computer, flash drive will be infected with the virus. In a flash drive that is infected, will form the autorun.inf file. Autorun.inf files will work automatically, every flash drive is inserted. Setting the default operating system is windows autorun when inserted an external device. Autorun windows, used by the autorun.inf, to enter into the computer. To protect your computer from viruses, there are a few things done:
1. Update anti-virus
2. Setting anti-virus in the guard position
3. Turn off windows autorun
4. Make anti virus auto scan flash drives
Turn off autorun Windows
Win Xp : Press START - run - regedit - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer - NoDriveTypeAutoRun - Value Data - Type = ff - OK
Win Vista / 7 : Press START - Control Panel - Hardware and Sound - Autoplay - uncheck "Use Autoplay for all media devices" - SAVE.
Using software USB Safely Remove. Open software USB Safely Remove - click View - Options - Global Autorun - After device plugging - click Add process to launch list - click browse, open directory C:\Program Files\ESET\ESET NOD32 Antivirus\ecls.exe - Open - then double click the drive letter, to add parameter %DriveLetter% - then, on the tab File name and parameters, write /log-file=c:\report.txt /log-rewrite /aind - OK. Then. click Add process to launch list - write "C:\report.txt" - then unchecked "Wait for the process to finish" and "Launch the process for drives only" OK - FINISH.
on Sep 26, 2011 | ESET NOD32 Antivirus
How unlock the wd my passport
Power down your computer.
Remove the screws on the rear of the case and remove the side panel.
Place the jumper on the back of the hard drive to the "write-enabled" position.
Consult your drive manual if unsure of how to do this for your specific Western Digital drive model.
Replace the side panel and restart the computer.
or
If you know the password, go into the installation disc that pops up in my computer when you plug in your wd hard drive (right click and then open, not autorun) there should be some sort of thing called security.
Possibly unlock, or something along those lines on there double click on it and type in your password it should unlock it then every time then that you plug in your hard drive, you might have to do this to access your files
hope this helps
Sep 19, 2012 | Western Digital 1TB My Passport Essential...
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 03, 2011 | Toshiba Computers & Internet
Hi there, I formatted the goflex because the seagate software was acting up in the vista 64x machine I'm using and was forcing me to use the seagate software without allowing for me to drag/drop and...
  1. In My Computer, right click on the drive you want to AutoPlay (it will not display if it is not plugged into your computer) and select AutoPlay.
  2. Choose the best option for you and press OK. Remember, there are several options available, including playing Media Files, copying pictures to your drive or if you have a program installed that can AutoPlay (autorun) such as PortableApps.com Menu from PortableApps.com. If you need to reset your options, just follow these instructions again!
And that's it!
Jun 06, 2011 | Seagate FreeAgent GoFlex Desk - 1 TB...
Can i delete folders that come with an new Acer external hard disc, e.g. autorun,etc.
Yes you can delete all the files safely. They are there to set encryption and make the hard drive auto-run when you plug it in. If you delete them your computer will still recognize the hard drive.
May 07, 2011 | Computers & Internet
How broken is this WD external HD
It's not broken.
Try to use a usb cable with 2 connectors(plugs). I mean, you plug one connector(plugs) in the hard drive and 2 connectors in the computer. Because you have 5 volts per usb connector.
Or you can use a small nokia charger to start the hard drive.
If you need further assistance please post
Mar 16, 2010 | Computers & Internet
My pendrive's autorun is deleted
Hi
Format the pendrive automatically ur problem will clear...
Thank you
Dec 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Unaccessible Drive
I have seen this before and the result was becuase the encryption was activated on the device (a password set) and then the software was lost of the PC - in your case due to the reimaging. Manual installation of the software is required. It is available from: http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Aug 11, 2007 | Maxtor OneTouch III Mini Edition (R01E100)...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
134 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
