Green Screen Mitsu WS 55411 The picture has a greenish tint to all the channels that are not on HD. The HD stations seem to be all right. This seems to be getting worse too. I was thinking it might need cleaned but I need a service manual to do this. Any Help? Thanks Mitsubishi 551330 Manual
  • 1 more comment
  • jonathant Jan 04, 2008
    I have the same problem with my SONY KDSR50XBR1 - HD looks fine but other non-HD channels have a green tint. Color adjustment/hue/sharpness ... changes have no effect
  • Anonymous Feb 05, 2008
    I'm also getting a greenish tint to my picture.Most HD chls look better but they're not as good as they used to be.
  • Anonymous Sep 09, 2008
    I have the same problem except mine has yellowish tint. I've tried all adjustment no affect. I don't know what to do. anyone?
I have the same tv but bigger, the issue is easy, just take off the speaker covers on the front the the center panel. after that you will need to unscrew the board in the center once you pulled the center panel off, after that you will see a box with 6 adjustment, black. the top row of three are what you are going to want to adjust, you can fix your green, red, blue tint here
Posted on Dec 10, 2007
Posted on Jan 14, 2008
SOURCE:
I got a Mitsubishi ws-55411 from a friend and I am trying to set up the cable. this is my first HD TV. The cable comes from a wall outlet (no cable box). I followed the manual and attached the cable into...
Go to the customer menu and switch the set from air-antenna to cable.
The set is in the air band and not the cable band hence only channels 2-13.
Let me know if you need help.
SD TECH
Apr 11, 2011 | Mitsubishi WS-55411 55" Rear Projection...
I have had this TV 6 months. Got it from a friend. The set worked perfectly in my house for 3 months. The color seems to have suddenly changed giving a gold tint to all cable channels, dvd's etc. I have...
I don't want to seem condescending in anyway but i would try checking all your cables to see if they are plugged in properly and if that doesn't help id suggest buying new cables and testing those to see if your old ones have died out. If it isn't the cables then return them but at the least we've figured out what it isn't. Other then that i cant really see of any problem other then an internal one.
Feb 28, 2011 | Mitsubishi WS-55411 55" Rear Projection...
Picture is fine but has a Red tint to it!
go in to a tv shop and say to them what you said to me thay should be able to tell you what to do but if u get no help don,t hesert
Jun 04, 2009 | Televison & Video
Peoples skin turn light green on screen
the cathode tubes are going out you need to replace them. there are three of them and they cost about 300 a piece. probably cheaper to replace the tv.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 04, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Powers off
these set have lots of bad conections and have a problem with two bad caps in the 9 volt reg curcuit one is right behind the reg
Nov 03, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Ekse
