Question about Philips Magnavox 27MS343S 27" TV
Model fp5251 g104 green screen
We found online that the tubes needs filled or cleaned but we don't know how to locate them and remove them to service.
TDA3006
Posted on Dec 09, 2007
SOURCE:
Can i fix my tv screen is red
Toshiba 36A10 36" TV is the model you have indicated---
If the screen is all red and or too bright (no green or blue can be seen) the problem is in one of two places: Either a shorted picture tube or the board that plugs onto the end of the tube.
That board sends red,green, and blue video and information to the picture tube via 3 pins on the tube (the K or cathode for each).
The set will have either 3 IC's on that board or 3 transistors, or a single larger IC for this.
to troubleshoot this:
I would locate the Red Cathode and unsolder that pin at the socket on that board--takes red out---if you have green and blue picture then---it is either the IC/transistor that feeds that on the board or the tube itself.
If it has 3 chips (usually will each have a metal plate attached for cooling) you can either remove and replace the red one OR what I do is swap it with the green or blue chip---if suddenly you now have a blue or green only screen you know that part is bad--simple as that.
If for any reason the picture tube turns out to be bad--you are finished and so is the set= way too expensive to replace it.
Let me know if you have questions or need advice.
Mar 28, 2012 | Toshiba 36A10 36" TV
Our ice maker just stopped making ice. we have replaced the filter and reset it and don't know what else to do
Hello there,
You need to run a check on your water inlet valve and the defrost thermostat.
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer. An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned. Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it. .
Before you begin to test your icemaker's water inlet valve, make sure you disconnect the appliance's power supply.
  1. Locate your icemaker's water inlet valve, it is typically located behind a refrigerator. Gently pull your refrigerator away from the wall. You may want to place scraps of carpet, of some other soft material below the fridge to prevent damage to the floor. Turn of the water valve's water supply by closing the shut-off valve in the waterline leading to the water valve. Remove the lower access panel on the back of the refrigerator using a screwdriver or a nut driver.
  2. Place a container under the valve to catch any water that may spill from the water valve and its fill tube. Remove the water valve's fill tubing. Loosen the flare nut on the brass fitting that is found on the inlet side of the water valve. You can use a wrench to loosen the flare nut.
  3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nut driver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
  4. There are two wires connecting to the terminals of your water inlet valve. If yours is a double solenoid water valve, it will have four wires. Be sure to label each wire so that you know where to reconnect them later. Firmly grasp the metal connector of the wires in order to remove the wires. You may need to use a pair of needle-nosed pliers. Do not pull on the wires themselves.
  5. Set your multi-tester to the R X 1 ohms setting to test for continuity. Place each of the multi-tester's leads on a terminal. Your multi-tester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
If the test you conduct with your icemaker water inlet valve does not produce these results, then you should replace the component.
To test you defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat To replace it: http://www.fixya.com/support/r10513650-replace_defrost_thermostat
If both have been tested and you found out the problem is not from either of them, then i will advice you replace the ice maker mechanism.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
WHERE DO YOU FILL TRANSMISSON WITH FLUID WHERE IS IT LOCATED i FOUND THE STICK
you need a long spout funnel with a small opening, it sits on that tube-you fill it there.
Sep 06, 2011 | 2006 Ford Five Hundred
Hey everyone. I have a Hitachi Rear projection Tv 53udx10b. I just replaced the convergence chips and cleaned all 3 CRT tubes. The picture definitely looks clearer now but the white tint has a slight...
You can try adjusting the color output. There are two ways to do this:
1) In the service menu (I don't know the codes or parameters...) I will not cover this for lack of info.
2) Via the focus block (Very touchy and difficult to get the mix right again if you get too far off)
If you take off the front cover there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need more red in the mix or just less blue and green. There is a screw for each color. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Barely turn the red up.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn andy of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Televison & Video
Hoover vacuum cleaner indicators stuck
the sensor is located in the tube that the bag mounts to, if you take the bag off of the unit and have an air compressor handy you can blow out the port hole this should dislodge the particulates that are causing the false reading, there is defintely a clog in the system. let me know if this helps thanks Don the Vacuum Doctor Alb, N.M.
Nov 05, 2009 | Vacuums
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Philips magnavox 9P6040C104
i just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Aug 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hello thanks the model # is FP5251 G105
Thats the PTV711 chassis phillips magnavox. I would suspect the vertical output IC needs to be resolderd. Its located on a aluminum heatsink and should have vertical stamped on the board near where the IC is located. Often when the vertical drops out it causes the CRTs not to light as a safety feature to protect the tubes. let me know if you need more assistance.
Jun 01, 2008 | Televison & Video
Screen all green
Your set is definatly Toshiba 43A9UE has Chassis A9PJ the parts may be hard to find give Toshiba the Chassis number that should be waht they need. Hope this helps. If you need some part in paticular such as a Green CRT let me know I will try to locate one for you, just would need the tube type and number off the tag on the tube.
Jan 25, 2008 | Televison & Video
Philips Magnovox FP5251 G104 (1995 model)...
if you can remove the screen you probably need to clean the mirror. if that is the case, don't use windex use a very mild solution of dish liquid (3-4 drops to the quart) then you will have to wash it several times with that. any harsher solution will remove the mirror surface. use a very soft , lint free cloth but not terry material. your bath room mirror has the "silver on the back side this one if it glass has the "silver on the front. if it is mylar don't press hard or it will streach and distort the pix. good luck
Aug 03, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
