Ive recently installed Virgin broadband and sincethe install my printer will not print from an open internet page. It still prints fine if I copy and paste to word. any ideas?
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software. Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer. Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete.
Installation without a Disc
Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers.Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system.Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation.Run a test print.
Check the printer setting selecting the background (embedded backgroud) in Option of printer properties.
Also try after resetting to defaults. If it is coming blank paper on online printing. otherwise, try to print a PDF file or already saved webpage and let me know.
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Network Configuration page NOTE The Network Configuration page is only available on the HP LaserJet p2015n, HP LaserJet p215tn, and HP LaserJet p215nw printers. A Network Configuration page prints whenever a printer configuration page is printed. You can also print a Network Configuration page by pressing the network Reset button at the back of the printer The Network Configuration page provides information about the network configuration, including the IP address, firmware revision, network statistics, protocol information, and so on. The Network Configuration page automatically prints when you print a configuration page from the control panel. ENWW Printer information pages 37 Using the HP Toolbox The HP Toolbox is a Web-based program that you can use for the following tasks: ● Check the printer status. ● Configure the printer settings. ● View troubleshooting information. ● View online documentation. You can view the HP Toolbox when the printer is directly connected to your computer or when you are using a supported network connection. You must have performed a complete software installation to use the HP Toolbox. NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you click a link in the Other Links area, you must have Internet access in order to go to the site associated with the link. See Other links for more information. To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1 connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system administrator or computer manufacturer's documentation for more information about installing the TCP/IP protocol and the DOT4 protocol.
Not sure but this printer may not be compatable with vista. OR.... you say it goes through the motions, does a page of paper come out? Did you try a different cartridge?
