Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cut the copy of image
When we are trying to copy of ID print out cut the image of that original size.
Adorjani Laszlo
Level 3:
  • Minolta Master 1,316 Answers
  • Posted on Aug 20, 2009
Adorjani Laszlo
Minolta Master
Level 3:
Answers
1316
Questions
Helped
457288
Points
2563
SET THE ORIGINAL SIZE AND THE PAPER TRAY.Change the security values.
How copy id card 8 pieces per page
* use a paint or photo editor program. copy and paste image as many that will fit the printed page. If size is not important then shrink it to the needed quantity.
* another way (if you have the proper card stock; IE; bussiness cards) is to use a preset program (check word or similar common program) or Template for the particular ID size needed. Set up printer with correct (usually perferated or pre-cut) card stock and use the built in program template to insert ID format with info and picture.
* Last; old school, use a copier and make 7 copies. cut out with clippers and glue them to one sheet. copy away using this "Master"
Aloha, ukeboy57
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
2answers
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
1helpful
The printing is too small
there should be a icon for expanding the original under the copy, number of copies screen. That will work for copying a document. If printing a document from a PC, use software such as WORD is increase the size of an image or text.
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Scanning an image only gives a scan 1/4 the size of original...
if u mean the size of image is reduced, as i know, the resolution of image, dpi, is too small --> try bigger dpi
if u mean the image is cut off, u have to clear the scan area or by default
Print or copy at A3
you will ahve to set this in the print properties when you select print on the file option go to paper and select bypass if you are using this tray and original size will be A4 print size will have to be set to A3
1helpful
Working on images
You cannot increase the resolution of a file. Even an image at 300 dpi has limits. You should check to see what the original actual pixel size of the image. This is the maximum size you can transform without losing resolution. Hope this helps!
Trying to print multiple images on one page
Unless you have Adoby writter or another software that writes in Adoby PDF format all you can do isto  copy and shrink the four at a copy place.Phisically  fit the four onto one sheet and make copies. Sorry  Adoby is propriatory format and windows word nor most others word processors will not reformat nor change it.
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
