Question about Epson Stylus CX4800 All-In-One InkJet Printer
My cd/dvd player dont work right
Everytime i put a disc in it sounds like it's choppy or skipping but their new disc audio and dvd. it used to play fine when it was brand new after a month or so it changed. i did install some dvd burnering software but it worked fine too and quit running right about the same time.
If your cd/dvd player doesnt work right after installing a Epson cx4800 model printer on your computer, specifically with the Vista OS, its due to reported issues with the cx4800 printer drivers conflicting with drivers tied to your cd player..supposedly.
Best advice is to uninstall the cx4800 software/drivers and see if your cd/dvd player works right. once confirmed it does, then try to get the windows os to automatically detect and install the cx4800 printer without using the printer drivers that came with the printer.
If after uninstall the printer drivers and your cd/dvd player still doesnt work properly....need likely to reinstall the cd/dvd drivers ..but that can be another ugly problem as for finding the right ones to reinstall.
Posted on Jan 02, 2008
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
My technics eh770 cd player is skipping so i now can't play cds
If the laser pickup is skipping, it is near end of life. Buy a CD cleaning kit and follow instructions, if there is no change the laser pickup assembly will need to be replaced, not cost effective to repair far cheaper to replace player.
Jun 09, 2012 | Technics Audio Players & Recorders
I think my lens is weak, the cd has to be ejected and inserted a couple of times before it works
Like any system, Xbox consoles require occasional cleaning to remain in peak condition. If you're experiencing skipping, poor sound quality, increased loading time, or any number of technical annoyances, simply cleaning your Xbox lens may correct the problem. The lens is responsible for reading all the data on your Xbox game discs; it is the most important part of the entire system. Cleaning the lens takes only a few minutes with the right cleaning product and know-how.
Difficulty: Easy
Instructions
Things You'll Need:
* CD lens cleaning disc
1.Purchase a CD lens cleaning disc. It is important that you buy a lens cleaner for a CD player, not a DVD player. Classic Xbox consoles are not DVD compatible, but they can play CDs. Some lens cleaning discs are marketed specifically as Xbox 360 cleaners, but these may not work in an original Xbox if the disc is DVD-formatted.
2.Turn on your television and Xbox just like you normally would to play a video game.
3.Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
4.Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
5.Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
6.Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
7.Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console
Aug 19, 2010 | Microsoft Xbox 360 Console
Cd player gives me a error code 4
The player doesn't like the brand of CDR your playing. Try using just a CD burner instead of a combo CD/DVD burner2_bing.gif. Also use Verbatim Pastel brand, because the player recognizes these discs easier. Also, it wouldn't hurt for you to run a commercial disc laser cleaner through this thing to clean the optical lens. Burn music using Nero software because its easy and the best.
Mar 13, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
CDX mp40 will skip when playing a cd everytime it gets bumped
122435678900566799878689866885689787896797689979088687768877698988768887878767886689985554587999877654323328900889
May 22, 2008 | Sony CDX-MP40 CD Player
CD/DVD Drive
Make sure that DMA is checked for the dvd player.
What program are you using to read (play) the DVD?
If you are using Windows media Player and Nero 6 you need to:
Go to
C:\Program Files\Common Files\Ahead\DSFilter\NeAudio.ax and NeVideo.ax
Don't delete these files!
For safety reason create New folder and move files in it.
Try this and let us know . Thanks
Oct 21, 2007 | Computers & Internet
Problem with playing DVD-R discs
The problem is that the mp3 format compresses the files to make them very small. The advance function on the dvd player was set up to advance, let's say, 1/2 second at a time. Well, the dvd or cd file will advance a 1/2 second, but an mp3 format file, which is way smaller, will advance the same distance on the disc which ends up being 10 seconds or so. I had the same problem with my panasonic. Solution would be to burn the files onto the disc in a cd format. You won't be able to put 100+ songs on the disc like you could with an mp3 format, but you will be able to controll the advancing a lot easier.
Oct 18, 2007 | Panasonic CQ-VD7001U Car DVD Player
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Epson Stylus CX4800 All-In-One InkJet Printer Logo
252 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
