Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi pd7200 42" plasma
Turned tv off on friday night, saturday morning switched tv on nothing happened, checked power supply to tv ok, no standby light on,
tv just 2 years old
  • Anonymous Dec 30, 2007
    Tv now 2 years old, watched TV and switched channel, all went out. No channel signal, only thing is that red LED turns green when you switch power on or off. Unplugged an then re-plugged but nothing changed. Screen remains black, with no sound an even no channel number in upper right corner. Don't know what to do.
Its a know fault with these sets - PDU's fail all time, look at
Posted on Mar 13, 2008
  • 148 Answers
Unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
Posted on Dec 28, 2007
I put the tv on standby last night tried to switch on this morning and cannot get anything no lights etc any ideas?
i guess you burnt the power already or check the plug and change the fuse in the plug . see what happens
Jan 13, 2018 | Hitachi Televison & Video
My hitachi plasma 42 PD7800TA does not turn on ,not even the standby ,the fuse is fine ,dont know what else to do? thanks Tony.
The power regulator board in your Hitachi is not switching. It is an SMPS [Switched Mode Power Supply]. Normally for plasma TVs the power supply repair will be almost impossibele due to lack of component availability. If the fuse is OK, definitley the switching process has failed it it. There is an IC which oscillates at high frequency, whic its oscillation signals are given to MOSFET transistors to chop the incoming AC, converted DC voltage. These switched voltage is passed through SMPS transofrmers which it turn generates secondary voltages that goes to different circuit boards of your TV. The power board is the most important section in a Plasma TV. it must be perfect in every respect in terms of secondary voltages. If any one of this voltage goes over than specified, the main boar will get damaged. So it is adviced to replace it as card basis, rather than making "sugery" to it. The power supply board can be had from Authorised Hitachi Service centers. You just give the the exact model number of your Hitachi TV. They will give you the orginal power supply board. Never play experiments with Plasma TV. OK.
Jul 15, 2011 | Hitachi PlasmaSync CMP4202U 42 in. HDTV...
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). has the original remote or a substitute remote if you need it. See .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
All of my power windows suddenly quit working they worked fine on Friday night and Saturday morning nothing--zilch We have checked fuses and circuit breakers---any ideas?
did you check the fuse or relay for windows! if need be take out master switch and check for power. if power, then maybe the ground wire is bad. have a good day !!
Dec 06, 2010 | 2004 Ford Explorer
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi p55h4011
if the tv is completely dead, your first step is to check the fuses in the power supply.but if you get the standby light, and nothing happens when you hit the power button, you need to call the repairman
good luck
Nov 07, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
349 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
