Question about Compaq (253219-002) Motherboard
Upgrading power supply
Ihave a compaq motherboard #252608-001 with 24 pin and 4pin processer plug with a basic nvida vidieo card , I wanted to put in my nvidia 7600 gsoc vidio card but it states that the min req are that a 350 watt psu is needed, my system has a 250 watt in and works fine, however i went and bought a psu of 500 watts and installed into my computer but get no response (no power, no led lights on mother board)
when i rehook my 250 watt supply everything runs fine , is it posable that the motherboard wont take a 500 watt psu?
when i look at the 24 pinn plug the coolmaster 500 watt plug has pinns in all holes, the first 500 watt antec psu had one pinn missing from top row , and the 250 psu that works the computer with no problems has one pinn missing from bottom row.
all psu where tested and checked out good
with only two wires to motherboard its hard to mess up, i know thier in the coresponding holes but just get no response from motherboard or psu!
any suggestions?
thank you
paul
    Genius:
  • 1,601 Answers
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Posted on Dec 02, 2007
SOURCE:
Video card upgrade compatibility for compaq presario sr1900 nx with windows 7 sp1 installed
All the information for your computers motherboard can be found here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00714521&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3190727#N534
The motherboard has a x16 PCI Express Video Card slot , so you should be able to put any PCI Express Video Card into this system. I would however refrain from putting something extremely powerful in there as you will encounter issues with the weak power supply in the system (Unless you upgrade the power supply too)
All modern video cards are PCI Express :)
Nov 30, 2013 | HP Compaq Presario SR1920NX PC Desktop
Boot up
did you put the 4pin power in the board and 24 pin in then check the cpu fan in the right place make sure that all plugs are in the right place as well put in video card
Jun 10, 2013 | EliteGroup ECS A740GM-M Motherboard -...
I have an old Hp Pavillion 505n desktop computer. Has been working fine for years. Awhile ago it would not turn on at all. The disk drive lite would flash on and off a few times then nothing. I removed the...
That 4 pin plug generally supplies power to the processor. It depends on the processor type. Unfortunately the next step in troubleshooting is to replace the motherboard or the processor and there really isn't a good way to know which one first.
Jul 29, 2011 | Computers & Internet
I have a Dell Optiplex 960 in which the motherboard had to be replaced. When I try to install nvida quadro 420 the machine reboots and will not go into windows
Could be a bad power supply. If the power supply can not handle the nvida quadro 420, the computer would be forced to restart. You computer doesn't essential need a graphics card to work. The mother board has one embedded so your desktop can run without it. My suggestion is to take the card out, reboot it, and find the correct drivers online before putting the card back into your motherboard.
May 12, 2011 | Computers & Internet
What is the watt for a power supply for a compaq presario sr2020nx. the computer will not turn on. i checked all other possible power sources.
Looks like it comes with a 550w power supply, so anything in that range would be fine. Below are the specifics if you need them.
Best of luck, William
-------- " Replacement power supply for Compaq Presario SR2020NX- 550 Watt Replacement Power Supply Upgrade
- One (1) 20+4 ATX Power Connection
- Two (2) SATA Connections
- Four (4) large molex connector (4-pin)
- One (1) One (1) floppy connector (4-pin)
- One (1) ATX 12V connector (4-pin)
- One (1) 6-pin PCI-Express Connection (6-pin)
- ATX Form Factor
- 575 Watt Replacement Power Supply
- Input Voltage: 100 - 240 Volts AC
- Width: 5.75"; Height: 3.25"; Depth: 6.0"
- Voltage: +3.3V (38A); +5V (40A); +12V (25A); -5V (0.5A); -12V (0.8A); +5V (2A)
SATA Support
- Supports both 20 and 24 pin motherboard. Great Power Supply Replacement or Upgrade. Compaq PSU Presario SR2020NX Power Supply Replacement"
Mar 03, 2011 | HP Compaq Presario SR2020NX PC Desktop
I don't have the manual for 277498-011
As for the Power Supply 99% sure it is an ATX which as long as you get the same Watt as the existing you will be okay. Make sure you look at your existing connectors to see if you have a 24 pin or 20pin motherboard and 4 pin or 8 pin additional power plug (black and yellow wires) and the new power supply has matching connectors....older ATX supplies have only 20 pins, but there are converters from 20 to 24 pin available.
Watch for the new power supplies and your drive connectors as some of the new power supplies have limited ATA plugs...if you have a lot of ATA devices you might need SATA power convertor plugs or ATA splitters to get all you ATA devices up.
Sep 11, 2009 | Compaq ( 277498-001) Motherboard
CASE DISASSEMBLY
first unscrew the cover of the computer, then
i suggest you take out all the connectors, so that you can dettach the power supply easily.remove the screws at the back of the power supply, which is in the back panel of the cpu chassis.
unplug the 24 or 20 pin connector from the cpu and all the power cords that supply the peripherals, take out the power supply and replace with a new one.
Plug the screws, plug the 20 or 24 pin power connector into your motherboard, and supply devices like your hard disk, cd rom by plugging in the power cords.
note, if your computer has a 4pin connector, make sure that you plug it in.
Heres a video tutorial on the step by step process.
http://www.youtube.com/watch?v=Y_Ch2Tdj1fM
hope this will help you out.
Thank you: )
Aug 09, 2009 | E-Machines T2885 PC Desktop
I change the power supply but i have a little problem. The new one on the ATX power connector have only 19 pin then 20 old one plus extra 4 pin for something else. The new power supply in Rosewill...
The extra 4 pins on the power supply's atx connector is for new motherboards that require 24pin power supplies. If your motherboard has a 20pin port, then only connect the 20pin portion of your power supply connector.
If your power supply has a 24pin fixed connector that can't be split into a 20+4pin configuration, and your motherboard doesn't have space to let the extra 4pins on the side, then you might want to consider returning the power supply and change it for one that can be used as a 20 or 24pin. Otherwise you will need to cut the extra 4pins apart.
Jan 05, 2009 | ASUS P4B533 Motherboard
Cant get any picture through the moniter tryed agp vidieo card and pci vidieo card still nothing the motherboard is out of emachines c2280 L7VMM2
Sounds like you have a bad power supply or motherboard. The power supplies in eMachines are not known for reliability, so try testing the system with another one. If you still have no video, you should replace the motherboard.
Dec 13, 2008 | EliteGroup L7VMM2 Motherboard
Help wiring normal hp compaq eplaced power supply no power
I am assuming this is a desktop and not a laptop. On the power supply you have a number of connectors. A 24 pin connector (like a lego block) or a 20 pin (leg block) with a 4 pin (in the pattern shown on a dice) Look at your motherboard and check whether you have any connectors which match these and plug them in. They only go one way round as they are shaped. You will need to plug in the wide white 4 pin connectors to everything else like your CD, your hard drives. The floppy drive has a separate smaller white connector. If you have a sata drive these are usually black and flat. Basically you need to connect some wires to your motherboard and one power cable to each of your devices, hard drive, CD/DVD, floppy drive. It doesnt matter which one you choose. Just one that will fit. If you have a souped up graphics card there may be a 6 pin connector for that either on the board itself or on the graphics card. The 6 pattern is the same as a 6 on a dice also.
Good luck.
Mar 12, 2008 | Computers & Internet
Compaq (253219-002) Motherboard Logo
200 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
