Question about Mercury P4VM800M7 Motherboard
Primary ide channels notworking sound greyed out
No sound primary ide channels have exclaimations marks mother board is asusk8v-vm
  • bartlover-31 Jan 19, 2009
    geen geluid
  • hmluciano Mar 24, 2009
    the question is... where to find those drivers?
    Problem Solver:
  • 6 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
0063
Posted on May 15, 2009
    Problem Solver:
  • 12 Answers
Download sound drivers if this won't work try uninstalling the device trough control panel then restart your PC, let the PC identify it again if the driver is needed please supply one.
Posted on Feb 05, 2008
SOURCE:
I have re-installed the windows XP home edition on my ASUS K8V-VM ACPI BIOS Revision, after re-formatting the C disk (which had lost its partition). Everything is OK except that the sound does not work...
you can download the sound driver from <a href="http://www.ziddu.com/download/11417644/AsusK8V-VMaudioforwindowsxp.zip.html" class="normal12blue"><b>http://www.ziddu.com/download/11417644/AsusK8V-VMaudioforwindowsxp.zip.html</b></a>
Aug 28, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: [email protected]
Oct 12, 2009 | Intel D865GVHZ Motherboard
PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Thanks
Mar 12, 2009 | ASUS P5GD1-VM Motherboard
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
I still cant figure it out....no sound...
Uninstall Previous Sound Drivers & Install new one. I am online now & can help you out with remote assistance.
Aug 06, 2008 | Computers & Internet
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
Play back
If your audio is Realtek then you should download it from realtek site.
To download click here
On this page driver is available for all OS. You may choose as per your OS i.e. XP.
Thanks
Iqbal
Mar 22, 2008 | ASUS K8V-MX Motherboard
Secondary IDE not working
Try to check if there are some capacitor has been damage. Replace the capacitor in each specific specification. You can do it yourself by using soldering iron.
Hope this is helpful to you.
Please vote me if I'm done correct solution.
Oct 30, 2007 | ASUS A8V-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
Mercury P4VM800M7 Motherboard Logo
414 people viewed this question
Top Mercury Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Davit Mamyan
Davit Mamyan
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
