The original Avic N1 only needed to have the parking brake wire grounded for video in motion. Then, the latter series came out and on the underside of the in-dash unit, they have a foil sticker that needed to be removed and a jumper carefully soldered on the circuit board. Avic N2's had a switch installed under this sticker to avoid people from making soldering mistakes. I think the N2 brain may be looking for an N2 unit and giving you trouble. more info on this subject is available @ www.avic411.com.
underneath the mounting bracket of the radio not the brain theres a silver sticker like mentioned above there are two silver solder points right beneath the sticker it must be jumped with a wire or you can use the solder to connect the two contact points after this you must still ground the green parking brake wire to the car.
2nd-(also my favorite choice and the one I'm using on my N5 & on my 7800dvd those who know pioneer know what i'm talking about)
buy a ptr7 pheriphial device and wire as follows (they come factory ready to bypass alpine and pioneer units)
wire as follows-white wire to green parking break of the deck your bypassing
red wire to vehicles 12v source
green wire from device to remote
black wire to vehicle ground wire
final important step I know because this happended to me
make sure you take a little screwdriver agfter wiring or something and switch the
PTR 7 to the off position-or else this will make the PTR7 not function correctly
Ummm, its against the law for the driver of a motor vehicle to able to see the screen of a tv or dvd player while the vehicle is in motion! Dummy, watch the road!!!!!!!!
You have to bypass the Parking Safety feature.
Here is the info I have found. I have not verified it myself for accuracy, so use at your own risk.
AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire.
