Question about Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Less than 1 year old
My camera will turn on and act as if it is going to be operable and then the lens will zoom in and out and then ask to be turned off and then back on again. The lens will not close when turned off. It acts like it is on when turned off. If not shut off when asked to do so, the camera automatically shuts down and the lens is still open. Even when I turn the switch to "off" the lens still stays out.
  • Hotiron Jan 05, 2008
    My FX01switches on and zooms in to maximum no functions are available
    in any mode .When I change to scene mode the options are scroling through unassisted none of the camer a control buttons work. Seems to be a software problem but I can't find the firmware anywhere Any help would be appreciated.
  • yayayoyoheho Jan 06, 2008
    Exact Same Problem...what the F???
Same problem with ours, only 7 months old. We returned to the seller under warranty, and they fixed the problem FOC. They stated "lens adjustment" on the repair invoice.
I think these machines are not as sturdy as we are led to believe, and the slightest knock or bump sends them a bit squew wiffy!
Posted on Jan 25, 2008
My 5 year old panasonic DMC-TZ27 seems to have jammed as it won't switch on!
Try the most basic step first. Please check if the battery is fully charged. If not it is not providing enough juice to the motor that turns the zoom lens. Please charge it fully first and give it a try.
If not, try re-setting the camera. you can find it in the menus.
if not the worst case scenario, the zoom motor is burnt, please take it to the service center for necessary repairs
Feb 22, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
To purchase a battery for the Panasonic Lumix DMC-FX01 is it easily available or does one need to have a specific serial number of the battery for the said camera
it is just a battery and camera manufacturers use generic batteries
take the old battery out and all you need is a battery the same shape , voltage and composition --ni-cad or metal hydroxide
they would be available at any camera shop or online from e-bay
Nov 23, 2017 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Aug 23, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic FX-01 Lens zoom ring (around shutter release) loose on
must to open ur camera and completly open that lense and clean well all gears then fix it back it will work
Jul 11, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
May 15, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
When I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Apr 05, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Bubbles in the photos
Hope the problem is not with the sensor. First try cleaning the lens with a clean dry cloth. If you can't get a microfiber cloth, use a clean cotton cloth. If you can still see some smears on the lens, put two drops of lens cleaning solution on the cloth and wipe carefully.
If you still find these bubbles, take the camera immediately to an authorized service center.
Nov 23, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
sir, it's a mechanical lens movement problum this is repairable
Dec 05, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
153 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
