Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
S1730 sharper image ionic breeze GP
Unit was unplugged and plugged back in while switched on. Wife says I burned it up. Can I reset or fix at home? Tried working bulb from second unit and it is good. What next? At home with burned up unit and wife, Roger.
  • rajalee Dec 04, 2007
    Sorry for the bad explanation. No, I put another known working bulb in the unit and it did not work.
  • rajalee Dec 10, 2007
    Where can I ship this unit for repair? Live in Hawaii. What is nearby and a proven fixer?
    Please send contact and mailing info. Aloha, Roger
    Sergeant:
    Champion:
  • 298 Answers
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
Posted on Dec 02, 2007
  • 1 more comment
  • Eugene Merritt Dec 02, 2007
  • Eugene Merritt Dec 04, 2007
    Without a schemateic I cant tell you much
    you could check for an open fuse burnt resistor
    anything thatl looks burnt.If you know how to use
    VOM check for open circuited or shorted
    components diodes, transistors,open resistors
    Warranty is shot now anyway Might be something
    simple like a fuse
  • Eugene Merritt Dec 10, 2007
    Check these numbers they could
    they may be able to help
    or take it back to
    where you obtained it
    they should be able to
    tell you something
    808-949-4100
    1450 Ala Moana Blvd., #2232
    Honolulu, HI 96814
    Kahului Shopping Center
    808-877-3006
    275 Kaahumanu Ave.
    Kahului, HI 96732
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
I have a Sharper Image Ionic Breeze GP S1730 the inside wire broke on. Does anyone know how to repair it????
One person used piano wire, but the diameter must be right so the cleaning beads can slide up and down on the wire when the unit is turned up and down.
Oct 22, 2013 | Sharper Image Ionic Breeze GP SI730 Air...
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
May 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Purchase Ionic Breeze #S1730GBX
Here is a link....actually you will need to copy and paste...its all one link....Ebay
http://cgi.ebay.com/SHARPER-IMAGE-GP-IONIC-BREEZE-AIR-PURIFIER-S1730-EXCT!_W0QQitemZ290304206696QQcmdZViewItem
I hope this helps....good luck and thanks for rating my effort.....the Fang.
Mar 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze
Is this the same as a S1730?...if so...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze gp s1730
Ionic breeze gp s1730 I had the same issue. There are two switches in this unit. One closes if the back cover is on, the other closes when the removeable grid is in. My problem was with the later. Mine had corroded wire ends where it is soldered to the small circuit board where the switch is attached to. It also had a bad switch that did not close the circuit and I suspect internal corrosion as well.
Unplug the unit and remove the grid.
Remove the 4 small phillps screws from the front grill, remove front grill.
Remove 2 selector whells from top, remove four screws.
Test the switch function with ohm meter
Oct 20, 2007 | Sharper Image Professional Plus Ionic...
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
266 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
