Guess G85675G Wrist Watch
Problem for Guess G85675G Wrist Watch
Guess g10150g wrist watch
By mr_pm78 on Dec 02, 2007
how do i remove the links so that i can adjust it to fit me
Same Problem
Nov 16, 2008
-   I had the same problem and these instructions were perfect. I had the watch adjusted in about fifteen minutes. It takes some patience, but you can definitely succeed if you follow the directions carefully. -   Guest
Best Solution
posted on Dec 02, 2007
Very Helpful)
Crafty1
Rank: Master
Rating: 86%, 49 votes
You really should take it to a jeweler who will have the proper tools to do this without damage to the band or watch, but if you feel you are able and don't mind the chance that you might scratch it.
...you will need a very small (the kind you use for your eye glasses) screw driver -flat head type, and a way to tap (a tack hammer) get a cloth to lay down (dark so you can see the small parts) and work on this surface. Look at the small holes on either side of the band and look for a ( - ) this is the end of the pin that must come out first and this is the direction you will force out the pin from the chamber. To force out the pin you must put the head of the very tiny screw driver on the OPPOSITE end and gently tap the screw driver to push the pin out, once you see a small portion of the pin, pull on it with a pair of pliers, but try not so squeeze it for fear of damage. Repeat at the next pin you wish to remove or 2 or 3 depending on how many you want out. Once you have removed all you need to, hold the links from where you have it separated together and push the pin back up inside the chamber **but make sure it is going back in as it came out---the pin will look sort of like a bobby-pin and the Rounded end goes in first** After you push it in by hand, you can use the tack hammer to tap it back down to make it flush, then use the screw driver to get is just below the surface of the band.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Nov 16, 2008
Very Helpful)
bingtamers
Rank: Apprentice
Rating: 100%, 1 votes
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Guess G85675G Wrist Watch
Questions and Unsolved Problems for Guess G85675G Wrist Watch
Do you recommend Guess G85675G Wrist Watch?
Answer
Answer
I need a replacement watch strap for my Ladies Kenneth Cole Watch KC2389?
Answer
lost winder i took it to different jewelers but said i need to take it to someone who deals in... (More)
Answer
I have a guess watch which i recently replaced the battery on. I cant seem to get the back metal... (More)
Answer
how to open a wrist watch dial .. have to stick back one of the digits
Answer
hi,..I bought my boyfriend guess watch, and it didn't come with the manual book, but then he got the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Guess G85675G Wrist Watch:
Top Watch Experts
Rank: Guru Guru
Solutions: 1630
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Watch Experts
Top Watch Repair
(800) 572-8263
Our techs have extensive training including at the...
Princeton Watches
(316) 683-3721
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
