Question about Sunbeam 2350 Heritage Series Mixer
Sunbeam Stand Mixer
First the blue beater stopped turning, took it back and exchanged, 4 days later the green beater won't turn, HELP!!!! Sunbeam offers no solution or troubleshooting guide, It cost $98.72. Has this happened to anyone else?
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Posted on Dec 24, 2007
  • Ivonne Mar 16, 2012
    Well I guess I will have to do the same my mixer is a Sunbeam Legacy Edition 450 watt and I also used it for 2 years. My Dad took it apart wich was pritty hard to do so, and now I cant find a replacement part anywhere. Iam kind of mad because I tought I was buying a good quality mixer wish was gonna last for a long time. what a shame money wasted. Ohh well I guess my next mixer is gonna be a Kitchen Aid.
SOURCE:
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
What is the best stand mixer to buy for home use? My 4 yr. old Sunbeam Heritage Series 450 watt Mix Master has stripped beater gears. Before that it wouldn't tilt back because of a loose screw. I don't...
the best stand mixer is a hobart n 50 its a little expensive, but if you use your mixer all the time, its worth the investment, buy 6 to 8 sunbeams, or kitchenaids, to 1HOBART N 50. metalgears in transmission, and in planetary,all the others have nylon gears
Jan 16, 2010 | Sunbeam 2351 Legacy Stand Mixer
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
The beaters won't go around. The motor is running
I can't solve this problem, but mine just died doing the very same thing. Motor is running, the revolving base is turning, and the beaters are just sitting there. Ruined an entire batch of divinity!
Aug 30, 2009 | Sunbeam Heritage 2346 Stand Mixer
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at [email protected]
Feb 18, 2009 | Sunbeam Food Mixers
Beaters don't turn
You should try to replace the beater turners or try to fix the problem that causes the beater turners not to work.
May 01, 2008 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam 2350 Heritage Series Mixer Logo
513 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
