Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
Whirlpool wahsing machine
The tub on my machine is not turning, my dad said I need a new belt but I cant find where the belt is?
  • Anonymous Dec 23, 2007
    I have a Whirpool Model: LSR72233EQ0 that does not turn or spin. Can you tell me what is the problem. I looked in the bottom and I saw a black rubber belt but I did not know where the belt is installed in the bottom.
    email:edwin9149@yahoo.com
  • 447 Answers
If yours is a whirlpool DIRECT DRIVE than it has no belt, may be why u cant seem to find one.
Posted on Dec 02, 2007
Whirlpool type 111 washer drains won't spin. makes loud screeching noise. installed new clutch assembly. still no spin.still high pitched noise (like a belt slipping) but type 111 is direct drive
Belt slipping? is the wash tub free to turn when empty? socks and small clothing items may be jammed in the drum / tub cavity caused by overloading if its stuck. May need to strip machine and remove drum to get them out.
Don't overload machines!
Feb 03, 2018 | Whirlpool Washing Machines
How do you replace the water inlet valve on the estate by whirlpool
You unplug the machine, turn off water and bleed off pressure, open the wahsing machine case, disconnect water hoses and electrical connections to the valve, and then unscrew the valve's mounting screws.
Oct 03, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I need to know how to install the new belt
The following link explains how to install the belt on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is an easy process, but it may take some effort to get the belt on the pulley. It is designed for a tight fit in order for the belt to stay in place on the tub pulley with no play in it. There is no tensioner and you do not loosen any motor mounts. Just make sure you hold the belt tightly in place with your hands and turn the entire tub pulley (like a steering wheel) in a clock-wise direction. The belt will stay on after you turn the pulley far enough for it to grip and stay in place.
If you have not purchased a replacement belt yet, the part number for the model you have this listed under is 8181670.
If you have questions, please let me know. I hope this helps you.
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum stuck sounds and looks like the bearings are broken
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer in order to fix it you need to replace both tubs and the basket at least i like to replace the pulley and belt as well but thats up to you
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The inner tub is out of balance and rubbing against the outer tub
The rear bearing is part of the back half of the outer tub. In some cases the basket will need replaced also if the shaft is scored. This is a big job. In most cases whirlpool will warranty the parts for 10 years but not the labor. Will need to check in your owners manual. Hope this helps
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100l belt will not stay on drum drive pully
I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
Nov 07, 2006 | Whirlpool GHW9100L Front Load Washer
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
82 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
