Well...HP models that have network capability have an "N" at the end of the model number. often those that have built-in wireless have a "W" somewhere as well.
Yours does not....so you cannot print DIRECTLY to the printer via Wireless LAN. You CAN however, connect it via a USB cable to a PC that is on your Network, (you must have wireless access to this network already for this to work, if not, then you have a whole different problem that is another question=How do I add "wireless" to my Local Area Network-LAN.)
Once the printer is properly installed, then you need to SHARE it to others on your Network. How this is done varies with what operating system you have...you did not tell us.
Yes, any Secure Digital (SD) memory card can be put into your hp Photosmart 620 camera safely. I would not go any bigger than 4 GB due to the limitations of some computers that you may use to download and process your photographs. And, you probably will want to pull off the phototgraphs and put them onto your computer for long term storage or for printing. That camera normally makes about a 1 Mb file for a JPEG image file. It will take a long time for you to fill up a 2 GB card; around 2,000 photographs.
Its either busy doing something or trying to tell you there is a fault in the system. Check your printer que to ensure there is no unfinshed print jobs.
Device cannot detect files on the memory card. Cause The memory card might be missing or inserted incorrectly.Verify that the memory card is inserted correctly.
The files might not be in the correct format.To
print from the device control panel, the files must be in the sRGB JPEG
format. To print other formats, you must use a software program on your
computer.
You might have inserted more than one memory card.Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
The printer just started spitting out blanks and the camera says printing canceled. A red light on the printer flashes once. I have changed cartidges and unplugged it.
