Question about Radio Communications
Kenwood TH-79E Handheld tranceiver faulty display
The display on my 2 mtr radio just shows hyroglifics (just dots broken up and flashing all over the place) The radio's audio is working fine and so are the frequencies I change to, but I don't know where I am going. It just went to this condition when I switched it on one day?
Any ideas guys?
Owen
  • Old-ham Dec 03, 2007
    Thanks, I will try this asap
  • 123 Answers
I think the display may have contact problems, or humidity. check for that conditions.
Posted on Dec 03, 2007
  • Ernesto  Garcia
    Ernesto Garcia Dec 03, 2007
    I had a TH-79 and that was the problem, bad contact on the dispaly
    New Friend:
Would you consider selling the radio for parts?
Frank Miller email: [email protected]
Posted on Dec 27, 2010
SOURCE:
My TH79 only shows channel numbers, what is the fault???
You should be able to enter the menus and change the freq display mode away from "alpha".
Jun 19, 2010 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
TH-79A Blank screen. It works with "F-switch on" but then goes blank.
Happened to me too. It takes some disassembling!!!! Between the screen and the underlying circuit board is a rubber strip with conductive material throughout which provides ''ground' for the display. This rubber wears out over time, but the quick fix is to turn it a quarter after cleaning and treating the contact surface with 'contact spray'( sparsely!!).
Job requires steady hand and pincers.
May 28, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
The volume control on my KENWOOD TH-78A no longer functions
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Apr 10, 2009 | Kenwood PB-18,...
Kenwood th - 79E playing up
Charger should be able to power the radio at 'EL' level, if NOTHNG happens, I'd say charger is on the blink.
Mar 05, 2009 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
My th-79a shows channel numbers only
RTFM Page 29
Press [BAND] + POWER ON to toggle Channel Display
Gerard - PE1OUD
Mar 04, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Unlocking Kenwood TH-22AT
http://www.radiomods.co.nz/kenwood/kenwoodth22.html
Dec 20, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
TH-79A amateur radio
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
Oct 30, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Urgently need aspare part for my Kenwood TS850 s/At HF Tranceiver
Watch ebay or QRZ.com for a used/non working unit that has a good display or maybe someone may part out a 850 on ebay.
Dec 30, 2017 | Kenwood Radio Communications
Kenwood 79a dual band transiever
There are several reasons for this, but one can be the flex that joins the display with the circuitry, carefully check if this is not broken or in this process or dirt.
Jul 02, 2007 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Radio Communications Logo
1,294 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
