Question about Kenmore Elite 45986 Front Load Washer
Model #11042822201 impeller will not turn. can i replace this myself?
    Champion:
  • 249 Answers
Yes,i take it its the pump empeller your on about just fit new pump,it should be easy,let me know Eire
Posted on Dec 06, 2007
SOURCE:
Your search - how to take apart a sundance hot tub lx wua400-ii motor to fix the bad impeller - did not
The numbers you provided are of no help.
What is it that you want to do? Replace the shaft seal, because it is leaking, and replace the impeller as well? Or did your impeller break, and you want to replace it?
a little more info, helps us, to help you. To begin... S/D pumps have a part number of 6500 Not, 3500
so... Is this your pump?
Sundance Spas Pump 6500 367
if so, these are difficult impellers to remove. Because you don't have the best of access, to grab a hold of the impeller, to twist it off the shaft, which will be spun counterclockwise. But first, you have to get access to the shaft, on the opposite side of the motor, and lock into place so it will not turn, as you unspin the impeller. You will either use a flat blade screwdriver or, or a 7/16 inch wrench.
good luck
Apr 13, 2015 | Pool & Spa
I have a Kenmore model 110 top loader. Will not drain or spin on any setting. I have checked and bypassed lid switch, I am able to lower drain tube to manually drain washer. Any suggestions?
Two listed causes for this problem are bad or broken drive belt (I would suspect warn if it still agitates, but does not spin).
Next one is bad drum motor and that calls for a replacement of the part.
I would myself look at a possible third.
You have a pump located at the outlet tubes connecting point beneath the drum. I would check that to see if it makes a clicking sound first to see if power is reaching so that it is getting power. If it is, then I would check the wiring to see which leads power the pumps motor and bench test it (after removing it) to see if it is frozen.
If it is not then check to see if the impeller itself is turning.
If frozen ir still working but impeller isn't turning you need to replace that.
I actually would bet 5 bucks that there is your problem.
Good luck.
Dec 03, 2014 | Washing Machines
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
Grinding noise in dishwasher. 4 day after warranty..Can I fix it myself...Need your help... Thank You, Sandi
Hi
Grinding noise is due to a cracked impeller which can be accessed by removing the spray arm. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Dishwashers
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Impeller or clog?
It sounds like you've done all the preliminaries, but now it appears you may have a bad drain pump. If the pump is only humming and water is not draining, the motor is probably bad. So...here's a few more questions to consider: 1. Is there water being left in the tub? Definitely a bad pump possibility. 2. When you had to pump open, were you able to spin the impeller? Sometimes small items like a piece of gravel can stop the impeller from turning. 3. Did you check the ENTIRE drain line all the way to the standpipe? You could have a pinched or clogged line still. If you've already tried everything, then I suggest purchasing a new drain pump. The prices vary depending on model, but they all are pretty simple to replace. Generally, there is one (maybe two) screws holding it in place. Disconnect the inlet and outlet drain hoses on the the pump, and remove the electrical connector. Make sure you have the washer unplugged when you do this. Also...to save you from a huge mess the next time, remove the drain hose from the standpipe at the wall and use you shop vac to drain the water THROUGH the drain line. That way you don't have a soppy mess to clean up afterwards. Good luck and let me know if there's anything else I can help you with.
Aug 21, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
