Question about Emerson EWV603 VHS VCR
Emerson VHS Audio Problem
I have a problem with my Emerson VHS it records the image well but there is almost no sound from what I actually recorded and a weird noise in the recording the volume goes up and down from time to time if you know what I mean but the weird noise stays the same. The TV is in its max volume and still the sound stays the same. It worked perfectly 3 days ago.
Thanks in advance
  • Anonymous May 26, 2008
2 Suggested Answers
SOURCE:
SOURCE: recording a tv show on a emerson vhs recorded problem
Allow the VCR to perform the much needed channel set up process... after this procedure, you will be able to record error-free...
Posted on Jul 05, 2008
How can i fix the audio problem that I'm having with my Emerson EWV401b VCR?
ensure your cables are plugged into the red and white ports in the back, that controls the volume on the back. If your using the red, bule and green cable you still must use the red and white.
Jun 28, 2014 | Emerson Ewv401b Da 4 Head Vhs Vcr Tape...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
Recording a tv show on a emerson vhs recorded problem
May 30, 2008 | Emerson EWV403 VHS VCR
DUBBING ONTO VHS FROM DVD
if you have two separate units, the best way is to connect s-video cable from the output of the dvd player to the input of the vcr. If not, second best is to connect the video/audio out of the dvd to the video/audio in of the vcr. Othwise the units may have a rf (75 ohm cable) output and the dvd usually sends channel 3 or channel 4 as an output when playing and the vcr must be tuned to this channel. Start the dvd, pause it, hit the vcr record button, then unpause the dvd.
Nov 30, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Recording Audio and Video from internet to VCR/VHS Also, how to record from pc to CD (audio)
You'll need a video card with TV-Out option, and hook up your display card's output to your TV,then you can record it with a VCR.
Sep 18, 2007 | Microsoft Office Outlook 2003 for PC
Emerson EWV603 VHS VCR Logo
37 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
