Question about RCA P61927 61" Rear Projection Television
Rca p61297 initially tv was wavy with a mix of colors then wouldn't turn on. we replaced a fuse temporarilty and it turned on with the same problem. we took the fuse out immediately as to not make problem worse. really trying to make hubby happy for christmas and superbowl. any ideas. please email kellysirois@yahoo.com
  • Murphy888 May 09, 2008
    We are experiencing wavy lines of blue and pink. We have been turning the TV off and on and this sometimes rectifies the problem. Then lately it's been getting worse and now sometimes it turn off and on by itself. Then won't turn back on.
  • 61 Answers
Sounds like you have a bad convergence power supply reg,part number is 215530,unplug the set remove the back cover on the right side above the module with 6 heat sinks,is were the pwr. supply is located,the part is on a heat sink on the board
Posted on Mar 07, 2008
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
Picture seems sunk in and the color distorted with doubleing effe
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 01, 2010 | RCA HD52W58 52" TV
I have a 3-yr old RCA HD61W66 projection TV that has a convergence problem. While watching the TV, there was a "flash" and the picture convergence went out resulting in a picture that was curved and had 3...
The cost about $300 parts and labors.U can do the repair ur self about $100,but require ordering the parts in the net.Must take the tv aparts.Have to desolder the parts,put in the parts correctly and resolder it.This website for the Net ordering parts.Tv Repair World.com.
Sep 08, 2009 | RCA HD61W66 61" Projection HDTV
TV screen turns totally green and has a wavy line
try remove the casing of ur tv go on the yoke, u see small board connecting to the yoke the try resolder all the part.Look on the main board some part are only lost look for it then resolder.Most especially the of chroma section wherein the colors are blending here i recommend to resloder properly sure to it that it will not jump to other pin.
Jun 18, 2009 | RCA 24F512T 24" TV
Rca tv stopped working when electricity turned off twice. Just will not come back on.-
open back panel to the far right where power cord comes in there is a 6amp 125volt fuse. Lowes , menards ect has them in a mix packet of common home fuses costs about $4.00. Had the same problem.
Jun 09, 2009 | RCA D52W135D 52 in. TV/DVD Combo
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WM24 52 in. tv issues
thats a convergence issue. Your model should still be under warranty. Call RCA and inform them that you need the number for the nearest authorized repair center that handles their warranty work.
Apr 22, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA P61927 61" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
