Question about RCA HD52W59 HDTV Projection Television
RCA TV MY MENU BOX KEEPS COMING UP WITHOUT THE REMOTE BEING PUSHED
  • snapper1967 Dec 09, 2007
    Genius:
  • 1,030 Answers
You might have a bad front control panel...it might be more but that were to start
Posted on Dec 07, 2007
SOURCE:
I need to know how to access menu or run channel scan on rca dta 800b1l converter box without the remote
There is not a way, unless you get a universal remote, scan for the code to control the box, and then get into the menu.
Dec 18, 2011 | RCA (DTA800B1) Video Converter
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Need to program JVC DVD player with RCA system
Go to http://remotefinder.rca.com/default.aspx?site=RCA follow instructions choose remote type you have then type of device u want 2 program remote for and then choose brand of that device and try the codes; simple
Dec 04, 2009 | RCA RCU300WBL Remote Control
RCA console TV need to change to video mode without remote
Your cable box has a program mode in
it .You may be able to program it to change
inputs on your tv Is it a comcast remote?
Jun 30, 2009 | RCA G27649 27" TV
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Guide Plus keeps popping up when the remote is used to turn TV on
there should be a way to turn it off in the user menu. usually it's under setup.
Jan 10, 2009 | RCA Universal Remote Control
RCA 27F520T child lock on without remote
go to menu and find the child lock and unlock it.
May 31, 2008 | RCA TruFlat 27F520T 27" TV
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
May 24, 2008 | RCA F27442 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 HDTV Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
