Question about Refrigerators
Frigidaire side by side frs26ts6dw2
Had a power surge to blackout now my frig is not getting cold. Fan is on but compressor is not comeing on. Is there a reset botton?
  • Anonymous Mar 02, 2009
    fridge tripped circuit breaker and now fridge will not work. Nothing comes on no lights no cooling. Checked circuit breaker by plugging lamp into outlet and it worked fine.
  • 447 Answers
No there is no reset button. Sounds like you need a new compressor relay. If its a tecumseh compressor you may to replace the whole compressor.
Posted on Dec 02, 2007
I have Frigidaire model# FRS26H5ASB4 and had a recent bad outlet surge of power. Now all light are on in the frig but the Compressor and Ice Maker are not working. How can I find out the what the prob
Ice maker won't work if compressor will not run, of course. I would suspect the main circuit board if there was a bad surge of electricity, or the problem could be at the compressor, i.e., a bad relay, overload, or start capacitor.
Oct 02, 2014 | Frigidaire FRS26H5AS Side by Side...
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
I have a ge GSH25JFXB WW side by side frig that was hit by a power surge. now, it does not cool like it use to. both the freezer and frig and warmer than before even when you turn it on full blast. they...
Start by checking the compressor. If it is running,you should tell by it being warm and a slight vibration/ will start and should run until thermostat stops it. Since it's not cooling, it should be running all the time. There are 2 copper or stainless tubes entering the compressor. One should be hot;the other cold. If both are same temp,or the compressor not running,or is hot to the touch, your compressor is done for(some have a removable connector with contacts that are replaceable) Compressors aren't cheap.
Nov 04, 2013 | GE Profile PSW26P Stainless Steel Side by...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Side by Side GE Frig not cooling
Check the superheating of the evaporator.
Mar 22, 2009 | GE Refrigerators
Freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Jan 28, 2009 | Frigidaire FRS26R4A Side by Side...
I have an 18 cu. ft. Frigidaire that the compressor is running on but the unit isn't getting cold enough. Is there a way to charge the refrigerant?
Odds are great that if you clean the condenser coil (the coil under your frig) and check the Condenser fan to be sure it is running. (little fan under the frig) Bet you its one or the other..*****
Sep 23, 2008 | Frigidaire Refrigerators
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore refrigerator model #106.53502300
Clean the coils.
If you have then there is a small fan that blows air across these coils, it is on when your freezer turns on. This would allow you to see if fan works. (usually when the fan fails you loose your freezer, bad repair people won't tell you to check fan)
Seals are a big issue. A good test put dollar bill into the door and try to pull out with door closed. It should be hard to remove. Seals are cheaper than new frig. A small air leak will lower cooling
Dec 01, 2007 | Frigidaire PLRS267ZAB Side by Side...
Refrigerators Logo
381 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
