Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Camera stays on
I recently purchased a Canon Digital XTi, and sometimes when I turn the camera switch to OFF, the green power light stays on but the camera appears to be off. this happens even when I do not have any pictures being written to the memory card. Conversely, when I turn the camera ON, the the camera appears to turn on, but the LCD screen will not turn on. Any possible solutions? I am new to the digital SLR world, so I am wondering if I am doing something wrong.
  • 1 more comment
  • gretz Dec 12, 2007
    We also wounder if we are causing this problem. It happens w/ both of our lens's. We have switched cameras and still no difference. It will work correctly just by r&r battery till next glitch. There doesn't seem to be any certain action that causes problem. We are also new to the digital. Thanks, for the forum.
  • balsam Dec 23, 2007
    I have the same problem. I received the camera as a gift today and it was working fine until I changed to a new EFS lens, then this problem occured right away. I removed the lens to be sure it was mounted properly and when replaced, it worked fine for an hour or so, then the problem re-occured. When the battery is removed for a few moments and replace, it allows me one shot at the menu, then nothing. No LCD and no shooting.
  • r5bales Jun 25, 2008
    Dh took photos, wanted me to download to e-mail. The green on/off light would not come on, camera stayed off. I took out the Memory card, put it back in, light turned on, camera didn't. Took battery out, put it back in, same deal. Got a new battery, got a new mem card. Same deal. This blankety blank camera is only about 3 months old.
    Novelist:
  • 148 Answers
This sounds like a systemic problem. (responding to 3 different inquiries with similar complaints)
the light stays on when writing to mem to warn/prevent you from losing images which happens from premature power down actions.
in this case you have signs that the mother boards are bad. call canon for advice,but i am sure they will instruct you to ship them for service. aside from damaging your camera, it does not sound like a user interaction issue.
good luck
mark
Posted on Dec 24, 2007
Power light is on, biut nothing works
Main Pcb K fuse gone its need to replace other wise it want work.
do it with canon repair centre
Aug 03, 2010 | Canon EOS Digital Rebel XTI Digital Camera
Canon EOS 400D will not power up replaced both batteries still no go although when a new main battery is inserted and the camera is turned on the green indicator lights and will not turn off until the...
Generally a fuse blows on these, on the DC/DC converter (psu ) board. This is situated on the front of the camera, fairly easy to get at just involves undoing loads of screws!! The fuse is marked "K", replace or short out with a thin piece of wire. May be caused by changing lenses with the power on, but not sure.
Watch for the charged flash capacitor though!!
Had this problem with mine.
Phil
Dec 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon 400d new batteries installed but will still not turn on.
Might seem obvious but check that the green light on the charging unit showed that the battery was fully charged before you put it in the camera. Make sure that the memory card is fully seated in the slot. If ok then either the charger is not charging or the on/off switch is faulty.
Jul 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon xti work turn on properly
Unfortunately, per the problem description, it seems your camera has an internal malfunction in either the main board or the DC/Dc converter printer cicuit boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the option of pay for its repair.
Best regards,
Apr 28, 2009 | Canon Digital Rebel XTi Digital Camera
Close Flash On Xti
Turn off the camera and remove the batteries. Then try to close the flash by pushing it down lightly. If it still won't remain closed, your camera is faulty and you should bring it back for a repair/replace.
Hope this helps,
/Chris
Jan 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Lcd screen stays on and cannot see subject
"Live View", where you can see and compose your picture on the LCD, was not available on any digital SLR before 2007 (the Rebel XTi came out in late 2006). So you need to compose your picture using the optical viewfinder, take your picture, and the picture shows up on the LCD after you've taken it.
But it's still faster than having to wait until the film is developed. :-)
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Power on Problem
please make sure the batteries you are using are genuine.
Jul 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
No power
This definitely looks like an issue with the Camera. I suggest contacting the Camera Tech Support immediately and request them to send the Camera to the service center. There are more Canon Rebel XTi owners, including me have experienced no-power issues albeit not exactly similar. More discussed here: http://www.fixya.com/support/t270989-xti_wont_power_up
I also do not think that any user action can fix this issue. Just call the tech support, and they may say that they never heard of this issue, please point them to this thread. Good luck.
Feb 21, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
283 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
