Question about Ahead Software Nero 5.5 (NERO5.5) for PC
Standby I am running Nero V5.5.2.9 on Windows XP. If I ask the PC go to standby twice, on the second time the PC 'Hangs' and I have to power down to recover the situation. If I uninstall Nero the PC works fine ! Any suggestions ?
  • 119 Answers
Nero uses a driver that interferes with hibernation, this problem doesn't exist with a nero before 5.0 so try that until they come with a new version
or try to live with it, sorry
Posted on Dec 02, 2007
Accidentally put my system on standby mode..using XP OS and DIY desktop.now i cannot get out of standby mode..check KB and mouse ok..any shortcut key or other ways i can start up and boot?even my two DVD...
I think you have to shut your computer down completely and reboot. This means that you will lose any work you didn't save before going in standby mode.
If your PC has a 'reset' button (usually located near the power button), press it. Your machine should reboot. If it doesn't or if you don't have one, you can try pressing and holding the power button for about 5 seconds. This should shut down your computer completely. Press the power button once more and it should boot normally, though you might get a warning saying Windows didn't shut down properly. If you get the choice, just choose to boot Windows normally. If pressing and holding the power button doesn't work, try looking for a power switch on the back of your machine. It should be near the power cable. Flip the switch, wait a few seconds and flip it again, then boot your computer as usual. You might get the same message which I mentioned above.
Mar 20, 2011 | Microsoft Computers & Internet
Dell pc with windows xp wont come out of standby mode to be able to power up pc and use it
First, how do you know it's in standby mode?
I would turn it off and disconnect from the power source. Then plug it back in and try to start it. If possible, start it in safe mode to see if you can identify what is happening. If in safe mode, do a system restore back a day or two.
var fctb_tool=null; function FCTB_Init_889fec04667049cfad3405862ebb395a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d9758fe2c8fa4d33bc34f8b0b6f0496c(t) { fctb_tool=t; start(fctb_tool); }
Jan 02, 2011 | Microsoft Windows XP Home Edition
My acer aspire one hangs when i set to standby mode
You don't specify but it seems like you are using Windows. This problem can be caused because you didn't set up an Account name. You can add one user, give yourself full admin rights, and do NOT require a password.
Default in Windows from standby is to log in as user...it goes wonky if no user is set. It can't find the user and does not know what to do, you have to reboot to get out of it, all stuff saved is lost.
BTW When you are at the Standby screen, hold down SHIFT key and it will change to Hibernate, if that option is available. Hibernate saves all your stuff to the hard drive and powers down..much better for batteries than Standby
Hope this helps
Jun 12, 2009 | Acer Aspire One PC Notebook
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
Windows XP Pro hangs on resume from standby or hibernate
There are many reasons this can happen, and unfortunately very difficult to pinpoint the issue in a particular case.
1. In your system BIOS there is usually two sleep mode (power states) you can select. It is Usually set to S3, change it to S1 (or vice versa), and disable wake on LAN (if available) unless you need it
2. Attempt a clean boot and see if some background startup item or service is causing the issue. see this article for troubleshooting startup items
3. Make sure you drivers (especially chipset, network, video and sound) and BIOS are up to date.
4. Disconnect as many things as you can (boot with just your keyboard, mouse and monitor) try a different mouse and keyboard.
I hope you find the cause, also check in Event Viewer to see if there are corresponding errors
Feb 05, 2009 | Microsoft Windows XP Professional With...
My PC won't shut down, standby or hibernate
Try the following
Control Panel -> System -> Advance Tab -> Settings under Startup and Recovery. Unselect Automatically Restart. Click Ok twice. Try to shutdown your pc and look for any error code.
Let me know if any error is displayed
Nov 24, 2008 | Microsoft Windows XP Home Edition
Acer 5110 won't standby properly
Check the power-save settings / properties. You may have to hit a specific key to "wake" it up. To make things worse, sometimes you have to hit yet ANOTHER key to wake it from hibernate.
Jan 11, 2008 | Acer Aspire Notebook PC
Want shut down
Click Start, then turn off computer, and make sure that your computer is not set to standby or hibernate. This works if you are running Windows XP or Windows 2000. Hope this helps!
Sep 11, 2007 | E-Machines eMachines Refurbished EMA...
Standby problem
When a alptop goes on to standby its quite common to require you to press the power button.Just turn off and power saving and standby problems you have by going into power management in control panel.
Mar 28, 2007 | HP Compaq Presario V2000 Notebook
Ahead Software Nero 5.5 (NERO5.5) for PC Logo
24 people viewed this question
Top Ahead Software Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
Lakshman P
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
