Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Brush on vac
The brush on our Hoover windtunnel canister won't rotate. I have checked the belt and did have to reattach it to the spindle on the motor, however it still will not rotate. I have checked for blockage and made sure the button was in the right position. Thanks
  • Margy1 Jan 12, 2008
    Dear domvac,
    Thank you so much!! I will check it out!
  • Anonymous Mar 24, 2014
    Hhow do I check the belt?
  • 126 Answers
I don't know how old your machine is, but the belt should be changed at least once a year and you should check to make sure the roller spins freely. There are bearings at either end of the roller and they will become contaminated with dirt and hair after a while and will need to be serviced. A new belt will help, but won't last if the roller is in need of service.
Posted on Jan 12, 2008
I have a Hoover upright windtunnel. The belt that spinns the brush keeps slipping from the spindle on the motor. How do i keep it on there?
for a temporary fix, double up a rubber band on the outer tip of the spindle. if the belt slips over that, it's stretched out too much. replace the belt
Feb 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Need help with Hoover S3765-040 WindTunnel Electronic Bagless Canister Vacuum. The belt that rotates the brush keeps slipping off. what to do?
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Sep 03, 2009 | Vacuums
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Replaced belts and brush roller will not rotate.
check to see if the spindle (small pencil-thin metal rod) is spinning where it projects from the motor. the belt wraps around this rod. if the rod is spinning when the vac is turned on your brush roller could be jammed. the bearing in the far sides of the brush roller frequently pick of long threads and hair and will stop the brush roller or the bearings sometimes overheat when worn and plastic will melt in this area causing stoppage.
Jul 10, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
Sep 13, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
110 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
