Question about Gateway MX6438 Notebook
Red line across top half of screen
Red lines across the top half of screen about half an inch apart. Red vertical line down the middle left side of the screen.
  • 89 Answers
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Posted on Jan 10, 2008
2 Suggested Answers
  • 163 Answers
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Posted on Jan 17, 2008
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Gateway MX6438 Notebook Logo
726 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
