Question about Toshiba Satellite A135 Notebook
GMA 4082n device driver not working properly code 39
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the driver HL-Dt-St DVDRAM GMA-4082N ATA Device is corrupt. I tried to update this online but found nothing.......... Could not find any file for this in my hard disc. right now I can see any drive other than C: in my computer. Neeta
  • 18 more comments
  • Neetav Dec 03, 2007
    Hi Romeet,
    Thanks for your response, I did what you say. I uninstalled HL-DT-ST DVDRAM GMA-4082N and restarted the laptop. But nothing happened, the system tryied to installes the driver than failed..........
    And the Position is as it was....
    By the I am using VISTA Home Premium and sick of it.....
    If you have any other idea please let me know...
    Thanks .
    NeetaV
  • Anonymous Dec 22, 2007
  • Mena G Dec 23, 2007
    I'm having the same problem exactly. Any ideas on how to fix it.
  • Anonymous Jan 27, 2008
    i have the same problem on compaq presario c500, with windows vista home premium system. does someone knows how to fix this?
  • Anonymous Feb 21, 2008
    Also have the Vista and the same cd drive. Exactly the same problem.
    I hate Vista and I think I hate Toshiba also.
  • senvat May 03, 2008
    i need burning software for this toshiba a100 psaane
  • Anonymous May 19, 2008
    This device cannot start. (Code 10)
    Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
  • kathiey Jun 03, 2008
    I have the same problem. Code 10 on my cddvd driver hl-dt-st-dvdram gma-4082n ata device. I have uninstalled - restarted my Dell laptop- Vista operating system
  • Anonymous Jun 06, 2008
    this is the deal my gilfriend got a lenovo laptop with this driver in it the damb thing got a virus and now the driver isnt installed and i dont have an instilation disk and the driver now shows up as hardware like a usb when u plug it in but when i click on it nothing happens
  • yoskakins Jun 24, 2008
    had code (19)
    The cd/dvd drive is not functioning
  • Anonymous Jul 10, 2008
    yes same problem code 39 error or missing!
  • Graphiti Jul 24, 2008
    I have a Lenovo 3000 N100 where I re-installed XP Pro after windows crashed and device manager will not allow me update either the firmware or driver, it too is giving error 39.
  • Anonymous Aug 21, 2008
    i also tried installing a usb cdwr and it also gets the error 39 problem if you have any other solutions i would appreaciate it. and i have installed and unistalled them both.. TY Russ
  • jhnstacy Sep 25, 2008
    HL-DT-ST DVDRAM GMA-4082N ATA disk drive is not working I where is driver?
  • Anonymous Sep 26, 2008
    My driver just stopped working. At first the CD part work and not the DVD, now neither of the two parts are working. The driver lights up and spins the disk but does nothing else. It wont even recognize that there is a disk in it, it just continues to spin.
  • Rimba Nov 04, 2008
    i have exactly the same problem as she has. my GMA 4082n is corrupted.
    actually it happened after my computer failed opening an MP3 cd. and
    then i just shut it down, and i needed too damned long time to wait it
    shut down.
    thank you
    Rimba
  • saul_01 Dec 31, 2008
    I HAVE THE SAME PROBLEM....AD DID THE SAME BUT I CAN'T SOLVE THE PROBLEM
  • Anonymous Jan 26, 2009
    i've got the same problem with my acer
  • eccollazo Mar 05, 2009
    Hello fellows.. i had the same problem, but it work quickly with the step deleting de upper and lower files..excellent work,
  • Anonymous May 04, 2009
    vista make me sick   xp rules
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
    President:
  • 1,257 Answers
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Posted on Mar 22, 2009
    Scholar:
  • 66 Answers
You can solve this problem by going to start, then run, type regedit. open hkey_local_machine, then system, then control, then class, then 4D36E965-E325-11CE-BFC1-08002BE10318, once in this go over to the right hand side and delete upper filters and then lower filters. restart your computer and your dvd/cd-rom drive will work properly, if you look in device manager there will no longer be a question mark and it will tell you all is working correctly.
Posted on Jan 29, 2008
  • 66 Answers
Hello Neeta,
This is Romeet,i will try and help you with this.Seems like a driver problem or a Burnt DVD ROM however lets try the easiset option first. Do you know how to boot your laptop into " Safe Mode " ? ( Press F8 key just after your laptop has turned on and the " TOSHIBA " logo has disappeared, from the list of menus choose " Safe Mode " and it will start loading windows. I am assuming you are using Windows XP..it will ask you if you want to continue loading windows xp in safe mode select yes.then:
Right Click the " My Computer " icon on your desktop and select " Properties " the system properties window will appear.
Go to " Hardware " and select " Device Manager "
Scroll down to the part where you see " DVD/CDROM Drives "and click the plus ( + ) sign next to it to open the submenu for it
From that submenu, uninstall HL-DT-ST DVDRAM GMA-4082N and select yes.
Restart your computer, and let me know if windows picks up the drive again,wait for a while before starting any processes as the new driver allocation / installation should happen automatically so do not interfere with that process.
Hope this helps
B.Regds
Romeet
Posted on Dec 02, 2007
Solution #3 works!!!, but I have used little different way... I have deleted lower filters and upper filters in HKEY_LOCAL_MACHINE --- SYSTEM --- ControlSet001 --- Control --- Class --- {4D36E965-E325-11CE-BFC1-08002BE10318} (differenth path) you can find your {4D36E965-E325-11CE-BFC1-08002BE10318} press Edit... Find...
Posted on Jul 12, 2008
Solution 2 worked!!!!!!!!! i cant fricking believe it thank you, best solution not so hot but thanks
Posted on Apr 02, 2008
I have same problem with Lenovo laptop error code 39 and tried solutions offerd for Toshiba but nothing happe ned
Posted on Feb 05, 2008
I had the same problem and Solution #2 didn't work. I ran a registry scan (RegCure) and found that a file, elbycdio.dll was missing in Windows\System32 directory, i googled the file, and downloaded it into the directory and restarted, voila!
Posted on Jan 02, 2008
Dont use your mind bcoz u hv extra MIND.
Posted on Dec 27, 2007
5 Suggested Answers
SOURCE:
worldvet
  • 859 Answers
SOURCE: GMA 4082n device driver not working properly code 39
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
Posted on Jun 09, 2008
untameddevil
  • 10 Answers
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Posted on Jul 20, 2008
pankaj_dic
  • 1252 Answers
check whether the device is detecting properly on bios or not
Posted on Oct 01, 2008
  • 10 Answers
SOURCE: Drive for HL-DT-ST DVDRAM GMA-4082N ATA Device
First thing I would do is go to My Computer or just Computer (under Vista) and see if drive exists. If it does show up it could be dirty and needs cleaning. If this doesn't help replace the drive. If it doesn't exist, Widows didn't see the drive at all and you need to pull it out and verify connections and possibly clean the connectors on DVD player. Plug it back in and Windows should say new drive found, if it doesn't I'd replace it.
Posted on Feb 15, 2009
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Nov 16, 2009 | Toshiba Satellite A135 Notebook
MY LAPTOP DOES NOT RECOGNIZE MY DVD/CD DRIVER... CODE 39
you need to do
1) confirm the dvd driver works ok at other same laptop or find a usb dvd drive adapter to check it works well or not, the dvd driver damage if not
2) check the dvd interface pins (no damage or disconnection) on the motherboard, there is hardware problem that you can not see or heard any lights and driving sounds when the power on
Feb 06, 2009 | Acer Aspire 5610-4648 Notebook
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Oct 01, 2008 | Computers & Internet
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
Regarrds,
Worldvet
Jun 08, 2008 | Toshiba Satellite P100 Notebook
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
no this is basic drive if this driver do not load on ur system check ur drive configuration means jumper setting if that is in master change and get it into slave any , primary or secondary.
Sep 23, 2007 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
16,884 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
