Question about SanDisk Sansa e250 MP3 Player
Charging how do I initially charge my e250? do I need a wall outlet?
    Scholar:
  • 155 Answers
You will need an accessory you can download one at macally.com or boxwave.com
Posted on Dec 08, 2007
SOURCE:
Bluetooth H520. Why has it been charging(initial charge) for 16 hrs and still flashes red?
Initial charge usually takes longer, but 16 hrs sounds long. Try charging at another outlet port or try another wire.
Mar 05, 2016 | Motorola Radio Communications
Batteries wont charge
You would need a voltmeter to check the charger in order to see if it is charging the batteries. New batteries if purchased from a reputable outfit will have a nominal charge and should work initially in order to test the scooter. Depending on the model check for blown fuses and disconnected wires on the battery boxes, connections, plugs and charging circuits including the wall outlet. The display on the scooter will indicate the state of charge and the key switch should work and give an initial indication that the scooter is on. If you provide make and model I can respond with more specific information.
Mar 23, 2014 | Health & Beauty
I have sony digital camara its not power on plz help me
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cameras
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Sansa MP3 Won't charge or come up on computer screen!?
sometimes if the mp3 is very cold or if it has been completely drained from battery it will do that, first try using a charger that you might have for your car, or something that you can charge it from a wall outlet.
Jan 29, 2009 | SanDisk Sansa e250 MP3 Player
Completely dead
did you try plugging/charging it into your computer?
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
Prombles Recharging Battery
Try upgrading the firmware of the player. If it still discharges quickly it may be the battery contact POP and have the battery replaced.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
