Question about RCA F32648 32" TV
Tv screen goes blank with a line across middle
Hi have a goodmans gtv76w2sil 28" tv after a few minutes the screen goes blank with a line across middle, but sound remains, any ideas and can you give me a ball park cost to repair please, Andy.....Darwen
    Sergeant:
    Champion:
  • 346 Answers
Change the vertical output ic
Posted on Jan 05, 2009
  • 372 Answers
Hi Andy.
This is a straight forward repair & wont be expensive.
The problem is either dry joints on frame chip or component going thermal and failing at a certain temperature.
Cost for repair will be between £35.00 to £55.00 ask for a quote first.
http://dysonmanuals.inc.io/
Chris.
Posted on Dec 02, 2007
SOURCE:
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 | LG 55LM6700
I turn my tv on and can see the picture for a minute or so...then it goes to just a line across the screen. It's like the screen closes, leaving a line in the middle (left to right of screen)
The problem is with its vertical scan output section. Visit this site. Similar fault and its way fro rectification are described here.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 18, 2012 | Mitsubishi CS-13103 TV
When i turn on the computer the gateway screen comes rightup but then the screen goes blank for a few minutes and the starts this screen that looks like a progress bar of vertical lines across the bottom...
sir,
1. you must download a spyware or anti virus, and just run it,
2. if the problem did not correct, save your files, re-format your computer,
3. Thanks!
Nov 25, 2010 | Gateway Computers & Internet
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Blank screen with a line across the middle
thats the VERTICAL OUTPUT IC that went bad , needs to be replaced . hope this helps
Apr 30, 2008 | Jensen 5" Color TV 5 in. Portable...
Panasonic TV model CT-27G7DR
Hi, Very often, the vertical IC is the culprit. What happens is due to excessive heat, the solder joints of the IC's pins gets undone. More often than not, re-applying heat through a soldering iron would solve the problem. It may also be a wise move to re-solder surrounding components and to check for any loose connections. Pls be reminded of safety precautions when working inside a TV unit. Hope this be of help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Sep 28, 2007 | Televison & Video
Problem with tv
Hi. No this is a run of the mill fault not that complicated. Repair shop should be able to repair with out any problems.
Aug 28, 2007 | Toshiba 28N33 28" TV
Missus driving me mad!! please help
this sympton is cause by a breakdown in the video amplifier, ABL (automatic brightness limiting) circuit, crt circuit or in the horizontal circuit and high voltage circuits. according to your experience, it seems that a certain component is already deteriorating, when it becomes hot it looses its function. probably ic, transistor, resistor or capacitor in the above circuits. but im sure its not the tube which is the most expensive of all the parts.
Jan 14, 2007 | Goodmans 217NS TV
RCA F32648 32" TV Logo
138 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
