Question about Electrolux Epic 6500 Vacuum
Starts and Stops
My 6500 starts and then stops after a second or two. The bag is new and there are no obstructions in the hose. The light that has an F is on. I assume this is a temperature sensor indicator, but the motor doesn't run long enough to get hot.
Does this mean the motor needs to be replaced?
  • 2 more comments
  • Anonymous Dec 12, 2007
    My epic 6500 also startsand stops with the bag full light on. Removing the hose allows the motor to keep running but partial blockage of the intake shuts it off again. I'm guessing the sensor that indicates the motor is under a load is faulty (a full bag creates a load on the motor). I want to disassemble and replace this sensor but need a manual or tech support. Please help, and thanks.
  • Tedd Smith
    Tedd Smith Jan 09, 2008
    I decided to disassemble and clean all the sensors and vacuum tubes inside. I think it was the small tube in the hose inlet area which is connected to the light that was signalling that something was wrong. After a cleaning and reassembly the unit is again working perfectly.
  • Anonymous Feb 08, 2008
    Because of this issue, I took the entire motor apart to clean, now I'm not sure exactly where the washers/bushings go. any diagrams out there that can help me put it back together?
  • Anonymous Mar 25, 2008
    I had the same problem. I took out the bag, left the door open and stuffed the bag housing with towels, held down the actuator button. It kept running. The actual problem was a small whole the size of a piece of lead in the plastic molding of the bag housing area. This whole is definitely not part of the design. The towels actually blocked airflow from escaping. So as a remedy I simply put tape over the whole and it is working perfectly once again.
    It appears the cause of my problem was air leakage versus excessive pressure that a full bag would present.
I WANT TO THANK THE PERSON THAT POSTED ON MARCH 25 2008 ABOUT THE PROBLEM HE OR SHE HAD ABOUT THE HOLE THE SIZE OF A PIECE OF PENCIL LEAD IN THE PLASTIC LINING FOR THE BAG. WOW!! I ALSO PUT A PIECE OF TAPE OVER IT AND IT NEVER RAN BETTER! I WOULD LIKE TO PERSONLY THANK THEM!! MY EMAIL IS.. donniemon@sbcglobal.net
Posted on May 25, 2008
  • 3 Answers
Check the air filter which is at the air output (blower) part of the canister, under the part where the attachments are stored. Also, I know how to disassemble, but the air filter is the likely problem.
Posted on Jan 08, 2008
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Why does it start, then immediately stop and bag light comes on?
My epic 6500 starts for a few seconds and turns off. With the filter light on. I take out the filter and it still does it. It only stays on if I cover the filter hole with my hand. Any solutions.
Oct 23, 2015 | Electrolux Epic 6500 Vacuum
Have a 6500 epic electrolux canister vac shuts off if you restrict the hose new bag not completly
Shake the bag if you've been cleaning up "fine" carpet freshener powder, drywall dust or anything extra fine as it clogs the pours of the bag and the machine stops thinking the bag is full. If this doesn't work, you'll have to have the control valve on top cleaned or replaced to correct the issue. Hope that helps!
May 16, 2014 | Electrolux Vacuums
My vacuum stops showing "bag full" even after I
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Nov 21, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Series6500SR
Dec 12, 2007 | Electrolux Epic 6500 Vacuum
Well, make sure the hose part is not clogged, this happened to my friends recently and their vacuum was smoking, if you're positive this isn't happening then it might be just the engine call the sellers, try to explain and see if they exchange for a new one or a refund.
Nov 29, 2007 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Nov 27, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
205 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
