Lanier 5645 paper jamb
Just prior to the printed sheet coming out, there is a jamb from the first guide.
The guide itself is causing the problem.
Anyone know how I can remove it to examine it. I would like to avoid a $300 service call.
thanks
    Novelist:
  • 158 Answers
The fuser assembly can be removed by sliding it out from the front of the machine. You may have to remove a retaining screw and plastic knob, all are accessed by opening the front copier cover. Unplug machine from wall before attempting this.
Posted on Dec 01, 2008
SOURCE:
Workcentre 5655. How do I complete the install phase?
[PDF]Xerox® WorkCentre® 5632 / 5638 / 5645 / 5655 ...
www.office.xerox.com/latest/W56BR-01.PDF
Xerox5632 / 5638 / 5645 / 5655. Multifunction System. Inspired redesign. WorkCentre®. 5632 / 5638 / 5645 / 5655. Tabloid-size. Black-and-white. Multifunction System ...
Oct 07, 2015 | Xerox Office Equipment & Supplies
Hoe do I empty the toner waste on an old Lanier 5645?
Its the brown belt thing on the right door, take off the 2 springs and remove the belt assy and empty, very messy...-Carl
Oct 16, 2014 | Lanier Office Equipment & Supplies
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
I need to purchase a 802.11b Interface Card for Lanier 5645. Do you know where I can find one?
contact your local lanier dealer and tell them what you need. beware though the 5645 is a few years old, it may not be available
Oct 12, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Apr 06, 2009 | Lanier Office Equipment & Supplies
How can I find a schematic design of Lanier Model 5635/5645 Copie
Goto my website and Download the file from the Public Folder. It is the only Point 2 Point in the folder.
Do not forget to vote Yes or No if this information was helpful
www.copytech21.spaces.live.com
Apr 01, 2009 | Lanier Office Equipment & Supplies
Lanier 5635/5645 copier
Now..... 'having to have 3500 sheets in it" doesn't really make sense does it?
No, You have either a safety switch that is out of adjustment, shorted out, or the lever that engages either of them is broken - either on the cover itself, or on the machine, where the LCT slides in /out.
Apr 01, 2009 | Ricoh FT5832 Copier
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
52 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
