Question about Linksys WPSM54G Print Server
Printer driver hangs on install
I have installed the printer server but after the laptop finds the printer it says it needs to update the driver. The driver already exists on the laptop but linksys insists on updating anyway. The update hangs after slowly progrssing to 76%. I have had to abort the rcess several times .
  • 141 Answers
Re: printer driver hangs on install
You get a ROOT HUB error when your USB port on your computer needs additional drivers. The print server drivers needs to configure your printer drivers. The only solution for this is CALL LINKSYS TECH SUPPORT. TELL THE TECHNICIAN THAT YOU HAVE A ROOT HUB ERROR. Linksys will send you ADDITIONAL DRIVERS for your root hub. UPDATE your ROOT HUB using the ADDITIONAL DRIVERS. Uninstall the WPSM54G from the add/remove programs. RUN SET UP COMPUTER AGAIN
Posted on Mar 12, 2008
0 characters
3 Points
Windows could not load the installer for NHCI. My printer is visible on the Keyspan server but I cannot print to it.
go to device manager and find the kepsan server, right click on the keyspan server with the yellow exclamation mark and say update driver, allow access to internet and it should install the driver...worked for me
Sep 01, 2010 | Keyspan USB Server US-4A (d47710) Print...
I have a DIR 320 router and print server. I used the built in printer set up wizard, but not able to download the printer driver to the printer set up. I have specified the exact location on the CD, but...
go to my computer right click u can see the device manager their click hardware the u can the hardware that is in yellow question mark.What only u need to do is to click update then locate the cd. especially the os ur using
Aug 24, 2009 | D-Link DP 300 (DP-300) Print Server
Can't get iogear print server to work.
you can also install the driver again if you already have the installed driver than it repair your driver otherwise it is installed.
Feb 20, 2009 | IOGear (GBP302KIT) Print Server
Can't find HP Photosmart 7150 driver during setup
check here.
Answer number 7 helped me when i had the same issues with the samsung ML-2010.
I installed the printer localy and then followed the sugestions at this link.
changed the server to a static ip
activated the required windows uttilities
changed the printer settings
hope this helps.
Jan 13, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I have a printer problem
Install the printer driver on the computer you want to use it on, Then in setup it SHOULD ask you if its a Local Printer or a Network printer, You choose network and it SHOULD find it on its own. Granted everything goes as it should...
Nov 24, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Adding a second printer to a d-link priter server
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
Jul 28, 2008 | D-Link DPR1260 Rangebooster G...
Can't finish printing first page of wireless print
try updating latest firmware on print server so windows vista could be compatible.
Jun 13, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link:
Nov 13, 2007 | IOGear GPSU21 Print Server
Linksys WPSM54G Print Server Logo
1,247 people viewed this question
Top Linksys Print Servers Experts
Jesus  Colon
Jesus Colon
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Linksys Print Server Expert? Answer questions, earn points and help others
