Question about Sanyo VWM-900 VHS VCR
SAP is displaying on my TV. Does that mean it is on? If so, how do I turn it off? I think it is under Menu, but I can't get it to go away. Thanks
    Sergeant:
  • 291 Answers
Sometimes under SETUP on the remote control [r/c]
Posted on Dec 10, 2008
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
The vcr writing on the tv screen says "SAP" and the sound won't play. How do I turn SAP off?
Hello
SAP means Secondary Audio Programme. To cancel this, you have to get into the Minu of your TV, and surf through to get the SAP display window. There you have to set the SAP of OFF. For more details go to the user manual of your TV. OK.
Apr 29, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Vizio gallivea some tv channels are in spanish and no sounds
GO into the customer menu with the remote and look at the audio settings---I would bet you will find SAP has been selected; this will give you some channels in spanish( SAP means secondary audio program) Monday night football and some other programs offer this for Spanish speaking people. Change the setting to Stereo or Mts away from SAp
I do this here for free so if this helps you give me a vote here---if you have questions or need help contact me by replying to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Vizio GV42L 42 in. LCD Television
We have a 32" Toshiba Tv and the sound is off on two channels and Stereo Sap is displayed on these two channels. Any suggestions as to how I could clear this?
turn off the sap in the audio menu. sap is "secondary audio programming" i believe, and sometimes stations will broadcast in spanish on this sap or will broadcast weather or emergency information. these channels are probably broadcasting a mute sound over the air.
Aug 19, 2009 | Televison & Video
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
I have a durabrand tv and need to figure out how to take sap off the tv. the tv is model DU2701
on the remote there may be a button marked MTS. if so press this button (toward tv) repeatedly till stereo mode displays. otherwise go into tv menu under audio section and scroll to parameter that allows you to adjust mono,stereo, or sap mode. mch
Mar 09, 2009 | Televison & Video
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
MONO - SAP
In the audio menu, you should be able to select stereo or turn off sAP -- you may have to unplug the set for about 20 seconds and restore power to reset it, or return it if the problem doesn't go away. If you end up replacing the set, try for a JVC, Panasonic or Toshiba if you can switch. I think they will last longer for you.
Jan 09, 2007 | Akai LCT2701TD Television
Sanyo VWM-900 VHS VCR Logo
131 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
