Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
Low audio input
I'm new to home recording. I've been using audacity software and just got a Behringer fca202. I'm plugging the mic directly into the 1/L jack in the back. The input from the mic is extremely low--like, I have to shout to get anything to register...
Any ideas?
Thanks!
Jodi
You need to use a mic preamp or a mixer with a mic preamp built in. The inputs on the FCA202 are line level and they won't work with a mic directly.
Posted on Dec 16, 2007
How can I stop clipping in audacity, Is there any way I can set audacity so it doesnt clip?
Sounds like you have too much volume range in your recording. If it is what I think it is you could use an automatic volume limiter on the input of the AudiCity recorder.
Aug 16, 2016 | Behringer C1U Studio Condenser USB...
Is mic jack in lenovo SL410 stereo?
From what I could see from the Specs of Lenovo SL410, it only takes a 3.5 mm Microphone Plug. You could always use a 3.5 mm Stereo Audio Mic Jack and use Software like Audacity for Stereo Audio Recordings.
Jan 10, 2015 | Lenovo ThinkPad Computers & Internet
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
http://www.logitech.com/en-us/support-downloads
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
How do I record from an external source (IPOD)
If recording from an iPod to a computer you need recording software like Audacity and a orch cable. Plug your patch into the input or mic plug on your pc, plug the other end into the iPod. Start the recording software select the input, start playing the iPod and hit record.
Mar 06, 2011 | Audio Players & Recorders
Volume is too low even with Gain turned to maximum. Also talking during recording gets picked up on the recording.
Your computer sound controls govern input volume and the use of a microphone. If you have a mic, find the control and turn it OFF.
Mar 04, 2011 | ION Audio TTUSB 10 Vinyl Recording USB...
I have a Behringer Mic C-1U and its not powering up!
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
Feb 25, 2011 | Behringer C1U Microphone
Set up audio mixer with PC
You must connect:
the main out of the 1202fx, or the ctrl room out of the 1202fx at your power amplifier's input (if there is one)
the line in 11/12 of the 1202fx at your pc's audio card line out. (for playing back)
the cd/tape out of the 1202fx at your pc's audio card line out. (for recording)
in case of a cd, connect it's line out at line in 5/6 (or 7/8, or 9/10) of 1202fx's
some mic at the mic 1 (or 2 or 3 or 4) of 1202fx.
That's the way you're going to have control for:
the mic level from channel 1 (etc).
cd level from channel 5/6 (etc).
pc playback from channel 11/12.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
About freeware softwares for audio recording and editing I can suggest you:
Audacity (homepage)
Wavepad sound editor (homepage)
In case of a problem or clarification about the connection or the cables, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 19, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Behringer F-CONTROL AUDIO... Problem:
I had a similar problem where as I could use the mic no problem at all but couldn't hear anything through the headphones. The simple solution was to disable the driver for my internal soundcard. It took me 48 hours to work it out! Good luck.
Jan 05, 2008 | Behringer FCA202 - FireWire Audio...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
231 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
