My new E-520 is almost always out of focus with 14-42mm and 40-150mm kit lenses when wide open. As the aperture is closed down the images get sharper and f/8 both give reasonably well focussed images. This is not a mild softening that would be excpected at large (wide) apertures -- the camera is clearly out of focus. Interstingly, in live view and using imager AF the pictures come out pretty well focussed and sharp at all apertures.
Last week I sent the camera and one of the lenses to Olympus for inspection and repair and got it back today. Absolutely nothing has changed although the service report says "focus recalibrated". From the test images they have included with the report it appears they took a few sots of a test screen at f/8 and send it back to me. The report also says "firmware updated" although it makes no sense. I already had the latest firmware and the firmware version on the camera and lens are the same before and after service!
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use...
(More)
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use the external flash. Too bad Olympus didn't think of this earlier. Any other thoughts?
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some...
(More)
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some cases take out the battery to have it unlocked and to be able to take a few shots again
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn...
(More)
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn the mode wheel or just tape the wheel gently it switch off again. is there a solution?
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in...
(More)
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in P, S or A modes, although the camera functions as normal in Auto or the pre-configured scene modes. Any ideas?
