My picture on the television seems to have lines going through the top of it. I don't know what caused it, just happened one day when I turned it on. The chassis is itc222a. Any suggestions on an at home fix.....RCA doesn't seem to back up their merchandise a year and a half old.....sad.. This tv was expensive, so I would love to know where to look for the problem=)
Thanks,
Krista
6 Other Users Have The Same Problem
Comment by jarturo, posted on May 10, 2008
My picture on the television seems to have lines going through the top of it. I don't know what caused it, just happened one day when I turned it on. The chassis is itc222a. Tv model R52WH74 RCA I need the schematics to find out how many volt it takes on pin 9 on plug BB202 I found a different schematics and it says I need 203 Volts but I have 230 Volts which causes the lines on the top I want to see how to lower this voltage if you have the service manual let me know
Comment by charlybalt, posted on Apr 25, 2008
after a year and a half my rca model r52wh74 went out my option mode to service it my self is off also peice of junk spoke to a service and he said it was a power converter box..........said the converter cost @100.00 dollars...plus his 100.00..................more money to waste
Comment by ramming, posted on Feb 28, 2008
Having the same problem came home after just watching it earlier and the TV had the lines and the 3d effect going on .
Comment by Guest, posted on Jan 07, 2008
Watching our RCA R52wh74 the other day and it went crazy, now it looks like a 3D movie when you watch without the glasses. It is just over one year old. RCA said its under warranty but not for labor (HOW DOES THAT MAKE SENSE???) ... Anyway, someone said it may be one of the projection bulbs. Either way, it is a piece of crap - breaking after one year and over 1000.00 dollars. Buy something else
Comment by Guest, posted on Jan 05, 2008
same Junk from Walmart r52wh74, 1 and a half years old, Solution: Buy a Sony or Sharp!
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Audio and Video Media problems?
RCA 5 disc entertainment system...
sony kv-27xbr45 standard...
picture in picture
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 03, 2008
my convergence is off and the option is erased from the setup menu how do i fix it its a rca model R52WH74
